help please
help please
can someone help me out my flowcode files not working as i want it to switches dont change pattern of leds can some one look at my file and alter it if needed
- leds.fcf
- (7 KiB) Downloaded 305 times
kersing
- Has thanked: 553 times
- Been thanked: 1081 times
Re: help please
Due to the use of the "while 1" loop in the "Yes" parts of the decision statements the code will never reach the point where it would read the switches again once you have pressed either switch 1 or 2. There are several ways to solve this, one is to run the loop a limited number of times. Another option would be to read the switches in the loop and exit that loop if a switch is pressed.
The attached example implements these options. If you press switch 1 all leds should light for 2 seconds. If you press switch 2 only 4 of the leds will light at a time, changing every .5 second until you press (and hold for up to 1 second) any of the switches.
Hope this helps.
Hope this helps.
- leds1.fcf
- leds1.fcf
- (7 KiB) Downloaded 335 times
― C.S. Lewis
― C.S. Lewis
