Is it possible to attach symbolic variable definitions and call them out in the code?
Like I would have a signal 'Sel' attached to say pin RA1. I would have a 'define Sel RA1' perhaps as supplemental code, and then in my flowchart would say something like 'SelState=Sel'
Big advantage is to have all definitions in one place for easy modifications and debugging. In the current situation if I am porting a program to another PIC with different pin connections I need to go through each and every statement block and chance the pin assignments.
Also, I remember reading that it should be possible to attache a notepage to a flowchart with engineering info but can't find it back. Was I dreaming ?
thanks,
Jan Didden
Linear Audio
