Building CASM file
Memory Usage Report
RAM available:768 bytes, used:42 bytes (5.5%), free:726 bytes (94.5%),
Heap size:726 bytes, Heap max single alloc:127 bytes
ROM available:16384 bytes, used:652 bytes (4.0%), free:15732 bytes (96.0%)
success
Return code = 0
Launching the programmer...
C:\Program Files (x86)\Matrix Multimedia\Flowcode V4\tools\PPP\PPPv3.exe -cs 2 -chip PIC18F2431 -nogui "18f2421 test.hex"
Sending program...
Erasing the PICmicro
NOTE: EEPROM data will also be erased!
Writing program memory
Writing configuration memory
Programming failed: <1><2><3><6>
That took 4.883 seconds
Return code = 0
FINISHEDNot sure what <1><2><3><6> represents.
Is it <1> = top config line etc.
Would someone mind correcting my config settings please. I plan to use internal 8MHz osc.
Thank you.
I am using EB006 V7 programmer with ppp
Seems there was a similar problem, which was not resolved using a chip from the same family:
http://www.matrixmultimedia.com/mmforum ... 26&p=15850
