USB Drivers not installing
kdoney34711
- Has thanked: 1 time
I have moved to a new box and installed flowcode but can not get the usb drivers to install. I have cleaned the system many times, rebooted, reinstalled and use several usb drivers available at your sight. I have used your exe installation process and the windows installation process and nothing seems to work. The windows installer reports no device information found. I am including a full report on the current system. Please advise quickly since this weekend's work is critical.
- sys.zip
- (38.39 KiB) Downloaded 551 times
Re: USB Drivers not installing
I take it you are using the EB006 or HP488 boards. What operating system are you using?
Please try the attached driver and see if this solves your issue.
- EB-006_driver.zip
- (1.22 MiB) Downloaded 613 times
kdoney34711
No, I am using a MIAC. The attached file has all of my operating system parameters. When ever I use the exe for installation, the process ends with a statement about a sucessful completion but then I still cannot connect.
Have you tried sending a program to the miac?
Reason I am asking is when you send a program to the miac, it will say to press the reset button on the miac. It is not until you press the reset button the miac is detected ,and not before (if I remember correctly) , so just try plugging a DC supply, and usb lead then press reset.
I have use miac on xp, vista and win 7 all with success, so long as you have got the latest miac drivers. I can't test my theroy as I have left my miac in work.
kdoney34711
Thanks all. It was a bad usb cable. Never had one of those before.
Kevin
Kevin
Sufre Haji Muhamad
- Flowcode V4 User
- Has thanked: 4 times
Re: MIAC Driver not installing
I have problem connecting Miac to my window 7, do I have to install the miac driver? I have found drivers from flowcode-4 cd namely:
1.Matrix_Miac_Driver_install,
2.Matrix_Miac_Driver_install (amd64)
When I run these drivers: warning appears, as "DPInst.exe does not execute on your operating system"
3. Matrix_Miac_Driver_install (ia64) - Warning appeared again "The version of this file is not compatible with the version of Windowyou re running. Check your computers's system information to see whether you need an x86 (32bit) or x64 (64bit) version of the program, and then contact the software publisher"
How do I know the software publisher? or Is there any other way to solve this problem??
I have tried using a resetting technique, but still Miac cannot found. By looking at the device manager, It showed the Unknown Device..
Please help....me..
Please help....me..
With windows 7 clicking on install with not install drivers. You will need to go into device manager and install drivers manually as explained in the tutorial here:
http://www.matrixmultimedia.com/mmforum ... f=2&t=8097
Before you do, you need to have miac connected and press reset, so you get the driver warning.
Although tutorial is about installing drivers for EB006,
Same method applies to miac, except you use miac drivers and not EB006 programmers drivers.
Sufre Haji Muhamad
- Flowcode V4 User
Hi medelec,
Thank you for your fast replied, I am able to sort it out within 10 minutes after struggling in 2 hours but I am using a Miac driver, E006 driver is not compatible with my HP laptop, I dont know why?
Anyhow thanks again...
Sorry it's my wording, I should of proof read a bit better and re-worded it slightly
The tutorial was for someone who had eb006 programmer, so that used the eb006 drivers only.
you have miac so you use miac drivers only, not eb006 drivers.
The install method is the same for both products.
If you have EB006 programmer connected then you should not get a warning about driver not compatible.
A warning for anyone who has both products, only have one product connected at a time, or programming will fail.
