Keypad 4x4
Jan Lichtenbelt
Has thanked: 128 times
Been thanked: 264 times
Keypad 4x4
Post by Jan Lichtenbelt »
User symbols can be introduced in the keypad. Symbols can be found e.g.
http://www.matrixmultimedia.com/softwar ... images.zip
Dragging symbols from the unzipped file will result in an error message and the flowcode program is not be accessible anymore. Unzipping the file is thus strongly recommended before using the symbols.
Re: Keypad 4x4
Hi Jan
Do you have a file that has been corrupted in this way. If you attach it to the forum here then we may be able to create a fix or workaround to this problem.
Jan Lichtenbelt
Re: Keypad 4x4
1. Just open a new flocode window. Introduce a keypad. Change the porperties to custom.
2. Drag a symbol from the zip file and an error message 461 returns (Specified format does not match fromat of data).
3. Close the error windows and try again (stupid of coarse, but it happens) the drag a symbol from the zip file into the keypad and the result is that the flowcode is completely blocked.
The solution is simple. First unzip the symbol file.
