i search a sample for SAA1064 IΒ²C 7segmentdriver.
Search Sample AVR and SAA1064-I2C LED Driver
Sean
- Has thanked: 6 times
- Been thanked: 44 times
Re: Search Sample AVR and SAA1064-I2C LED Driver
Hello Joe,
We do not have any examples for this specific device, but it can be controlled using the Flowcode I2C component. Its interface appears to be similar to the 23017 I/O expander used for the I/O expansion article:
http://www.matrixmultimedia.com/mmforum ... =26&t=4868
It should be possible to reuse the register read and write macros from the I2C version of the example program (with slight modifications) to communicate with the SAA1064.
Thanks,
it soo simple
My Clock:
it soo simple
My Clock:
int counter = 0;
char sekunde = 0;
char minute = 0;
char stunde = 0;
void wait() {
Delay_ms(100);
char seconds, minutes, hours, day, month, year; // Global date/time variables
// Software I2C connections
sbit Soft_I2C_Scl_Output at PORTD2_bit; // PORTC0_bit;
sbit Soft_I2C_Sda_Output at PORTD1_bit; // PORTC1_bit;
sbit Soft_I2C_Scl_Input at PIND2_bit; // PINC0_bit;
sbit Soft_I2C_Sda_Input at PIND1_bit; // PINC1_bit;
sbit Soft_I2C_Scl_Direction at DDD2_bit; // DDC0_bit;
sbit Soft_I2C_Sda_Direction at DDD1_bit; // DDC1_bit;
// End Software I2C connections
//--------------------- Display SAA 1064
void Display() {
char Zahl[10] = {0xdb,0x11,0xcd,0x9d,0x17,0x9e,0xde,0x91,0xdf,0x9f};
char temp = 0;
Soft_I2C_Start(); // Issue start signal
Soft_I2C_Write(0x70); // Address SAA 1064
Soft_I2C_Write(0); // Start
Soft_I2C_Write(0xf7); // config
if (sekunde % 2)
temp = Zahl[stunde % 10] | 0x20;
else
temp = Zahl[stunde % 10];
Soft_I2C_Write(Zahl[stunde / 10 ]); // Position 4, from left 1
Soft_I2C_Write( temp ); // Position 3, from left 2
Soft_I2C_Write(Zahl[minute / 10]); // Position 2, from left 3
Soft_I2C_Write(Zahl[minute % 10]); // position , from left 4
Soft_I2C_Stop(); // Issue stop signal
//-------------------- Output values to LCD
//------------------ Performs project-wide init
void Init_Main() {
Soft_I2C_Init(); // Initialize Soft I2C communication
//----------------- Main procedure
void main() {
Init_Main(); // Perform initialization
DDRA = 0xff; // set direction to be output
PORTA = 0x00; // turn OFF the PORTA leds
counter = 0;
Dispaly(); // Display with sec-takt over dp2
while (1) { // Endless loop
Delay_ms(500); // Wait 1 second
++sekunde;
if (sekunde == 60)
sekunde = 0;
++minute;
if (minute == 60)
minute = 0;
++stunde;
if (stunde == 24)
stunde = 0;
