For my latest project I'm using four LUT's (4 x 50)
Since they are bytes, they only cover 0-255
Is there a way (without doubling quantities of LUT and using: number=LUT x 100+LUTb , e.g. I If number is 2614, then 1st LUT = 26 and second LUT=14) of using a 10bit LUT?. I need to retrieve numbers in the range of 0 to 3274
The only other way I can think of is using int arrays. Since I have made a spread sheet to create and paste LUT data directly into flowcode, I want to avoid arrays if i can.
Look-up-tables.
Re: Look-up-tables.
Hello Medelec
You should be able to do something like this.
temph = LUT[pos]
templ = LUTB[pos]
intvar = (temph * 100) + templ
temph = LUT[pos]
templ = LUTB[pos]
Re: Look-up-tables.
Thanks for reply Ben. I was after a method which did not require doubling of LUTBenj wrote:Hello Medelec
temph = LUT[pos]
templ = LUTB[pos]
is your method same as example I posted which I am trying to avoid?:
Am I correct in saying all LUT are 8 bit only?medelec35 wrote:(without doubling quantities of LUT and using: number=LUT x 100+LUTb
Re: Look-up-tables.
Hello Medelec
Sorry I think I misread,
You can create a 16-bit LUT in Flowcode if you need to by creating a int array though as you suggested this would cause problems initialising the data.
You can also create a C code array by doing something similar to this in the supplementary code window.
int LUT[2] = {1234, 2345};
This would be stored in RAM and would have a maximum size of 128 int variables.
A ROM array can only be 8-bits max.
Re: Look-up-tables.
Thanks Ben. I only said avoiding arrays due to spreadsheet copy and paste. Since you have overcome that with C code, so long as don't go above max RAM capacity, your solution will best way forward!
Re: Look-up-tables.
int FCV_LUT[2] = {1234, 2345};Problem is I now get following error message:
m:\NEW_HIGH_EFF_HR_V3_BASIC1B_EBM_Fans.c(209:223): error: too many initializers
m:\NEW_HIGH_EFF_HR_V3_BASIC1B_EBM_Fans.c(209:26): error: failed to initialize variable 'FCV_STD155_RPMF1'
m:\NEW_HIGH_EFF_HR_V3_BASIC1B_EBM_Fans.c(211:220): error: too many initializers
m:\NEW_HIGH_EFF_HR_V3_BASIC1B_EBM_Fans.c(211:26): error: failed to initialize variable If that is the case then that would mean assigning variable with a value or a calculation involving int variable in a C box rather then a calculation box?
Or have I got that wrong and error is for a different reason.
This is the code I used in supplementary code window:
Int FCV_STD155_RPMF1[40]={807,844,880,917,954,990,1027,1060,1093,1126,1159,1192,1225,1258,1291,1324,1357,1390,1419,1442,1465,
1488,1511,1534,1557,1580,1603,1626,1649,1672,1696,1715,1734,1753,1772,1791,1810,1829,1848,1867,1886};Martin
Re: Look-up-tables.
Figured out what was causing error.
too many initializers just simply mean you have more than declared number of items.
After count, I had 41 variables instead of declared 40.
Now compiles ok. Only problem is still going over memory allocation.
Re: Look-up-tables.
I have had an idea. I have run out of ram for variables location. What i can do is use flowcode to write 8bit numbers to flash, then retrieve stored numbers like an array. I believe u need to use flash.h is that correct?
