Is it possible for matrix to create a model for simulating a Port Extender, so inputs and outputs can be connected to the Port Extender in simulation.
Is it possible to connect LCD display to Port Extender, i could not find a item on that.
Simulate Port Extender
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Re: Simulate Port Extender
I'm not sure it will be easy to simulate the use of a port extender, so I can't see this happening.
As for using an LCD on one, this is possible. But you will need to modify the C code of the LCD component so that the low-level i/o routines work through the expander instead of directly to the device.
