I have not used my flowcode 4 and e programming board for a few months. I set it up and tried to compile to chip (a 16f877a
but i get the following message :
Error: Failed to open:libc.pic16.lib or C:\Program Files\SourceBoost\lib/libc.pic16.lib
failure
Return code = -2
Flowcode was unable to assemble the ASM file due to the following errors:
FINISHED
I have restored defaults in the compiler options but still nothing works. I urgently need to get this program to work
Your help will be appreciated
Gerhard
not compiling to chip
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Re: not compiling to chip
This is not the default setting, so I don't know what would have caused these defaults to be wrong. On installation, the correct defaults would be:jacobsg wrote:Error: Failed to open:libc.pic16.lib or C:\Program Files\SourceBoost\lib/libc.pic16.lib
-ld "[INSTALLDIR]BoostC\lib" libc.pic16.lib flowcode.pic16.lib rand.pic16.lib float.pic16.lib "%f.obj" -t PIC%p -d "%d" -p "%f"You need to make sure this is set up correctly and that the file is there. If you are still having problems, then I suggest you uninstall and reinstall Flowcode.
