Object Bar problem
Object Bar problem
Greetings Steve and or Ben, I just installed and updated to the latest version and the Icons are jumbled around in the component or Object Tabs. Thanks for your help.
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Re: Object Bar problem
Hi Chet,
The fix is detailed in these posts:
http://www.matrixmultimedia.com/mmforum ... bar#p17026
http://www.matrixmultimedia.com/mmforum ... bar#p15986
I hope to provide a better fix in the next Flowcode update.
I tried the suggested regedit and reinstall to no avail. I'll just wait for your next update I guess.
- Steve
Chet,
Deleting that "HKCU\Software\MatrixMM\...\Workspace" registry entry should definitely solve this problem for you. Note that Flowcode should not be running at the time.
The first link you suggested solved the problem the second link did not, at least for me. Thanks
