Hi Benj,
Thanks for the help.
i get a problem with Longitude reading some of the time it reads 0.1087 which is correct and then some times 0.0087.
i have 12 satellites being received. latitude reads good all the time.
Thanks,
Wayne
GPS Longitude
wayne millard
- Has thanked: 7 times
- Been thanked: 12 times
Re: GPS Longitude
Hello Wayne
I too am getting this problem and I think that it is down to a rounding error in BoostC. The input coordinate must be changing ever so slightly and this is being multiplied into a big rounding error.
To get around this you could try adding this C code in a C code icon at the start of your program
float_detect_tininess = x;
Where x represents the following:
float_tininess_after_rounding = 0
float_tininess_before_rounding = 1
If this doesn't help then you could change to the HiTech compiler that handles Floating point nativley. This way you can also get away with not using the float manipulation functions.
