Changing TRM setup "on the run"
ksor
Post by ksor »
I do beleave something IS wrong when changing the prescaling in a TMR-setup (at least with TMR0) while program is running in HW.
In two branches of my program I use different prescaler in setup of TMR0 - COUNTING mode have one setting of prescaler for TMR0 and RPM mode has another.
When changing from one mode to the other I DISABLE the TMR, change the prescaler and resume.
In HW the changing DO NOT take place - it seems like the TMR stops or can't be started again in the "new" mode.
I can choose between the two branches with a CHANGE-OVER switch.
If I leave the switch in the position where the timer now do NOT run and cut off power and connects again - then it works fine again - until I change the switch - then I have to cut/connect power again for it to work.
I beleave a "software reset" would do the job - can this be done in Flowcode ?
Best regards
KSor, Denmark
Re: Changing TRM setup "on the run"
Its working fine for me, though I do have other interrupts going on. Try manually clearing the interrupt flag this may help.
ksor
Post by ksor »
Please send your program to me so I can see.
You didn't comment on if it is possible to make a "software reset".
Best regards
KSor, Denmark
Hello Ksor,
I have attached the program.
A software reset can be done by using the following C code inside a C code icon in your program.
reset();
Ex7. Storage Scope.fcf
(19.28 KiB) Downloaded 352 times
ksor
Post by ksor »
... and you even do no DISABLE before changing TMR-setup.
I made some changes to the structure of my main flowchart to get the reset(); to fit - and it works fine.
I then tried to delete the reset ... and now it works fine too - it's just spooky I think - but never mind, it works !
Best regards
KSor, Denmark
The program works so that one of the switch case branches disables the timer interrupt. This is always called before switching the interrupt prescaler and re-enabling.
ksor
Post by ksor »
Ok - I didn't notice that - but I was very keen remembering to DISABLE, change prescaler and enable again - but it still wouldn't do it !
But now when I changed a little in the structure of the main flowchar ... then it works - even WITHOUT the reset();
So that's it ... no more struckle with that program !
Have a nice week-end ! :lol:
Best regards
KSor, Denmark
