Dear MM team,
When i click the stop button, i know that the simulation stops, i do not need a messagebox.
It irratates me verry much that it has to be closed by a click.
Please make a setting to get rid of this box. If there is a reason why you must show this box, let it dissapear within 3 seconds or so.
Message Box "Simulation has ended"
Re: Message Box "Simulation has ended"
It does Disappear automatically after about 4 seconds with V4.2.3.58.ncc1502 wrote: If there is a reason why you must show this box, let it dissapear within 3 seconds or so.
This was first sorted with version v4.1.1.55
Installation version = 4.1.1
Release date = 14th August 2009
Flowcode exe version = v4.1.1.55
* Main EXE
- Added VNET functionality, including grouped simulation
- Added Tabbed interface options
- Added Component Categories on toolbar
- Fixed STDIO redirection bug
- Fixed array <VariableUsed> bug
- Fixed double-delete issue
- Added auto closing "Simulation Complete" message
- Added delay to fix intermittent ICD problem
- String parameter to user macro fix
- Byte now accepted in place of a string
- Added secondary splash screen
- Fixed MX_VAR_SEPARATOR issue
- Fixed project options page
- Added/Updated the icons for Panel Objects
- Improved context menu for components
- Misc minor bug fixesWhat version are you running?
rehan
- Flowcode V4 User
One quick note:
If you keep your mouse hovering over the message box then it will not go away. This is the default way how auto closing message boxes work.
rehan
rehan
