Olympus RM-1 IR Shutter Release
Harry Tuttle
Has thanked: 2 times
Been thanked: 10 times
Post by Harry Tuttle »
OlympusRemoteV4.fcf
(8 KiB) Downloaded 755 times
Simple programme that replicates the shutter release from the RM-1infra red remote control.
(57.16 KiB) Downloaded 4921 times
I have used a 16F877A as this is part of a larger project, it should work on any chip with PWM output.
The PWM output is used to produce the 38kHz Carrier frequency. Pin 16 is connected to an IR LED via a 220ohm resistor.
(143.09 KiB) Downloaded 4921 times
I have tested this on a Olympus E-3, although I believe this remote control works on other models.
Harry Tuttle
Re: Olympus RM-1 IR Shutter Release
(210.98 KiB) Downloaded 2920 times
Harry Tuttle
The transmitted signal comprises of :
9mSec burst
4.5mSec space
Address first byte
Address second byte
Command
NOTcommand
The logic bits are:
Logic 0 1.12mSec long
(48.7 KiB) Downloaded 4920 times
Logic 1 2.25mSec long
(53.79 KiB) Downloaded 4920 times
For more on Extended NEC protocol see:
http://www.sbprojects.com/knowledge/ir/nec.htm
(52.71 KiB) Downloaded 4920 times
I know someone who wanted one of these.
Thanks.
Great article.
