I've got an ECIO 40 board which I am currently using. I've got windows 7 64 bit on my computer - and the drivers on the website are not compatible. Is it possible for someone to send me the 64bit drivers please.
Thanks.
ECIO40 - 64 bt drivers needed
Re: ECIO40 - 64 bt drivers needed
Hello Audette,
Please download the drivers from here.
http://www.matrixmultimedia.com/softwar ... driver.zip
Once you have downloaded the package go into the folder for your device and then run the dpinst_amd64.exe file. This will preinstall the drivers which should allow the drivers to be installed correctly when you plug in your ECIO device.
Please let me know if you have any problems.
Hi Ben,
thanks for your help. It worked without any problems
- Audette
- Audette
