When compiling to hex I get a general error with line numbers.
By compiling flowchart, would someone mind letting me know where I have gone wrong please.
I am not that familiar with C, if indeed that is the cause.
Thank you.
Launching the compiler...
C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\boostc.pic16.flowcode.exe -v -t PIC16F737 "pwm flowcode test.c"
BoostC Optimizing C Compiler Version 6.95 (for PIC16 architecture)
http://www.sourceboost.com
Copyright(C) 2004-2009 Pavel Baranov
Copyright(C) 2004-2009 David Hobday
Licensed to FlowCode User under Single user Pro License for 1 node(s)
Limitations: PIC12,PIC16 max code size:Unlimited, max RAM banks:Unlimited
pwm flowcode test.c
Starting preprocessor: C:\PROGRA~1\MATRIX~1\FLOWCO~2\BoostC\pp.exe "E:\pwm flowcode test.c" -i C:\PROGRA~1\MATRIX~1\FLOWCO~2\BoostC\include -d _PIC16F737 -la -c2 -o "E:\pwm flowcode test.pp" -v -d _BOOSTC -d _PIC16
E:\pwm flowcode test.c(160): error: general error
E:\pwm flowcode test.c(169): error: general error
pwm flowcode test.c failure
failure
Return code = 1
FINISHED
