I just updated and installed the latest version 4.3.7.63 on my windows 7 (64bit) (I was using 4.2)
When I open a file it now takes several minutes to load. With V4.2 the same file loaded in seconds.
I tried configuration mode using XP sp3 as the setting, but it made no difference.
Any suggestions?
Cruzxia
Slow Loading File
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Re: Slow Loading File
Hi Cruzxia,
This is a known issue where the flowchart is very large or there are lots of tabs/windows open at the same time. Please see here:
http://www.matrixmultimedia.com/mmforum ... 248#p18499
The problem was caused by a small "fix" for a flowchart redrawing issue. The workaround explained in the link above seems to minimise the problem.
