Dear MM.
Please could you help me out on this littler error. I am trying to demonstrate the Formula Flowcode buggy to one of my freinds using Flowcode 4.3.7.63. I can write the routine and simulate it, but when I compile I get to following errors:
File name: C:\Documents and Settings\user1\Desktop\flowcode\jbuggy sound meter.c
Generated by: Flowcode v4.3.7.63
Date: Wednesday, May 05, 2010 11:53:17
Licence: Professional
Registered to: Julian Silver
Launching the compiler...
C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\boostc.pic18.flowcode.exe -v -t PIC18F4455 "jbuggy sound meter.c"
BoostC Optimizing C Compiler Version 6.95 (for PIC18 architecture)
http://www.sourceboost.com
Copyright(C) 2004-2009 Pavel Baranov
Copyright(C) 2004-2009 David Hobday
Licensed to FlowCode User under Single user Pro License for 1 node(s)
Limitations: PIC18 max code size:Unlimited, max RAM banks:Unlimited
Starting preprocessor: C:\PROGRA~1\MATRIX~1\FLOWCO~3\BoostC\pp.exe "C:\Documents and Settings\user1\Desktop\flowcode\jbuggy sound meter.c" -i C:\PROGRA~1\MATRIX~1\FLOWCO~3\BoostC\include -d _PIC18F4455 -la -c2 -o "C:\Documents and Settings\user1\Desktop\flowcode\jbuggy sound meter.pp" -v -d _BOOSTC -d _PIC18
jbuggy sound meter.c success
success
Return code = 0
C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\boostlink.pic.exe -rb 0x800 -ld "C:\Program Files\SourceBoost\lib" libc.pic18.lib "jbuggy sound meter.obj" -t PIC18F4455 -d "C:\Documents and Settings\user1\Desktop\flowcode" -p "jbuggy sound meter"
BoostLink Optimizing Linker Version 6.95
Error: Unresolved external function:'float32_to_int32(float)'
Error: Unresolved external function:'float32_from_int32(signed long)'
Error: Unresolved external function:'float32_le(float,float)'
This goes on for several pages.
Can you help me out?
Regds...J
Formula Flowcode Buggy compile errors in ver4
juliansilver
- Flowcode v5 User
Re: Formula Flowcode Buggy compile errors in ver4
Please can you post your Flowcode program and the C file that is generated onto the forum and I will look into this problem for you.
juliansilver
- Flowcode v5 User
Here are the attachments you requested.
Ta alot. Regds...jules
- jbuggy sound meter.c
- (17.53 KiB) Downloaded 601 times
- jbuggy sound meter.fcf
- (8 KiB) Downloaded 572 times
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
I think your linker parameters are not quite correct. Here's what mine are:
Looking at your compilation messages, your one is set to this:
I think you need to change yours to this:
Note that the 16 and 18 in the lib filenames is not a problem - Flowcode automatically alters these depending on the target device.
It also seems that you are using a different version of the BoostC compiler - i.e. not the one that comes with Flowcode. This might cause you some problems. If it does, you could try removing the "flowcode.pic16.lib" library from the above parameters.
-ld "D:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\lib" libc.pic16.lib flowcode.pic16.lib rand.pic16.lib float.pic16.lib "%f.obj" -t PIC%p -d "%d" -p "%f"Code: Select all
-ld "C:\Program Files\SourceBoost\lib" libc.pic18.lib "%f.obj" -t PIC%p -d "%d" -p "%f"Code: Select all
-ld "C:\Program Files\SourceBoost\lib" libc.pic18.lib flowcode.pic16.lib rand.pic16.lib float.pic16.lib "%f.obj" -t PIC%p -d "%d" -p "%f"It also seems that you are using a different version of the BoostC compiler - i.e. not the one that comes with Flowcode. This might cause you some problems. If it does, you could try removing the "flowcode.pic16.lib" library from the above parameters.
juliansilver
- Flowcode v5 User
Dear Steve.
That seemed to work.
I'm not sure how those settings got there. As far as the BootC being different I am a bit stumped. It all seems to work now though.
Thanks again. Regds...jules
