problem in compiling the program
arush
Post by arush »
hello BEN,
i have gone through the teacher notes of zigbee, then i starting again with the flowcode version-4 on my laptop, this time nothing happened while starting the software and i tried using examples, i started with the second example as you said, then i simulation completed, i tried compiling that machine level program onto the chip, i have even checked all the conections, but its giving error while compilation process. the error is regarding the ''key validation'' of my flowcode software. i am copying that full error message. please tell me, how can i get rid of this problem.
kind regards-a.
ASM FILE MESSAGE
;// Code Generator: BoostC Compiler - http://www.sourceboost.com
;// Version : 6.95
;// License Type : Lite License (Unregistered)
;// Limitations : PIC12,PIC16 max code size:2048 words, max RAM banks:2, Non commercial use only
License limitations exceeded!
C FILE MESSAGE
File name: C:\Documents and Settings\UserXP\Desktop\PROJECT\Flowcode_V4_Examples\Examples\Components\Zigbee\Exercise 2\Node 1.c
Generated by: Flowcode v4.3.7.63
Date: Tuesday, May 04, 2010 22:17:20
Licence: 50 User
Registered to: Southampton Solent University
NOT FOR COMMERCIAL USE
Launching the compiler...
C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\boostc.pic16.flowcode.exe -v -t PIC16F877A "Node 1.c"
BoostC Optimizing C Compiler Version 6.95 (for PIC16 architecture)
Copyright(C) 2004-2009 Pavel Baranov
Copyright(C) 2004-2009 David Hobday
Single user Lite License (Unregistered) for 0 node(s)
Limitations: PIC12,PIC16 max code size:2048 words, max RAM banks:2, Non commercial use only
Node 1.c
Starting preprocessor: C:\PROGRA~1\MATRIX~1\FLOWCO~1\BoostC\pp.exe "C:\Documents and Settings\UserXP\Desktop\PROJECT\Flowcode_V4_Examples\Examples\Components\Zigbee\Exercise 2\Node 1.c" -i C:\PROGRA~1\MATRIX~1\FLOWCO~1\BoostC\include -d _PIC16F877A -la -c2 -o "C:\Documents and Settings\UserXP\Desktop\PROJECT\Flowcode_V4_Examples\Examples\Components\Zigbee\Exercise 2\Node 1.pp" -v -d _BOOSTC -d _PIC16
Node 1.c success
success
Return code = 0
C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\boostlink.pic.exe -ld "C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\lib" libc.pic16.lib flowcode.pic16.lib rand.pic16.lib float.pic16.lib "Node 1.obj" -t PIC16F877A -d "C:\Documents and Settings\UserXP\Desktop\PROJECT\Flowcode_V4_Examples\Examples\Components\Zigbee\Exercise 2" -p "Node 1"
BoostLink Optimizing Linker Version 6.95
Caution: argument of 'delay_us' calls must have a value of 1 or more
Caution: Delay inaccurrate: 'delay_us', Delay overhead:0ms, Unit delay:0.00101725ms, Delay resolution:1 units
Caution: Delay inaccurrate: 'delay_ms', Delay overhead:0ms, Unit delay:1.00016ms, Delay resolution:1 units
Warning unreferenced functions removed:
FCI_FLOAT_TO_STRING in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
FCI_NUMBER_TO_HEX in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
FCI_STRING_TO_INT in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
FCI_STRING_TO_FLOAT in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
isinf in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
FCD_gLCD0_PrintNumber in: C:\Documents and Settings\UserXP\Desktop\PROJECT\Flowcode_V4_Examples\Examples\Components\Zigbee\Exercise 2\Node 1.c
FCD_gLCD0_DrawLine in: C:\Documents and Settings\UserXP\Desktop\PROJECT\Flowcode_V4_Examples\Examples\Components\Zigbee\Exercise 2\Node 1.c
FCD_gLCD0_DrawBox in: C:\Documents and Settings\UserXP\Desktop\PROJECT\Flowcode_V4_Examples\Examples\Components\Zigbee\Exercise 2\Node 1.c
FCD_gLCD0_SetForeColor in: C:\Documents and Settings\UserXP\Desktop\PROJECT\Flowcode_V4_Examples\Examples\Components\Zigbee\Exercise 2\Node 1.c
FCD_gLCD0_SetBackColor in: C:\Documents and Settings\UserXP\Desktop\PROJECT\Flowcode_V4_Examples\Examples\Components\Zigbee\Exercise 2\Node 1.c
FCD_gLCD0_SPI_Init in: C:\Documents and Settings\UserXP\Desktop\PROJECT\Flowcode_V4_Examples\Examples\Components\Zigbee\Exercise 2\Node 1.c
FCD_gLCD0_SPI_Send_Char in: C:\Documents and Settings\UserXP\Desktop\PROJECT\Flowcode_V4_Examples\Examples\Components\Zigbee\Exercise 2\Node 1.c
FCD_gLCD0_Set_Data_Direction in: C:\Documents and Settings\UserXP\Desktop\PROJECT\Flowcode_V4_Examples\Examples\Components\Zigbee\Exercise 2\Node 1.c
FCD_gLCD0_StrobeE in: C:\Documents and Settings\UserXP\Desktop\PROJECT\Flowcode_V4_Examples\Examples\Components\Zigbee\Exercise 2\Node 1.c
FCD_gLCD0_Update_Slave in: C:\Documents and Settings\UserXP\Desktop\PROJECT\Flowcode_V4_Examples\Examples\Components\Zigbee\Exercise 2\Node 1.c
FCD_gLCD0_CommandWithData in: C:\Documents and Settings\UserXP\Desktop\PROJECT\Flowcode_V4_Examples\Examples\Components\Zigbee\Exercise 2\Node 1.c
FCD_gLCD0_CommandWith2Data in: C:\Documents and Settings\UserXP\Desktop\PROJECT\Flowcode_V4_Examples\Examples\Components\Zigbee\Exercise 2\Node 1.c
FCD_Zigbee0_ToHexString in: C:\Documents and Settings\UserXP\Desktop\PROJECT\Flowcode_V4_Examples\Examples\Components\Zigbee\Exercise 2\Node 1.c
FCD_Zigbee0_Scan_Network in: C:\Documents and Settings\UserXP\Desktop\PROJECT\Flowcode_V4_Examples\Examples\Components\Zigbee\Exercise 2\Node 1.c
FCD_Zigbee0_Connect_To_Address in: C:\Documents and Settings\UserXP\Desktop\PROJECT\Flowcode_V4_Examples\Examples\Components\Zigbee\Exercise 2\Node 1.c
FCD_Zigbee0_Connect_From_Library in: C:\Documents and Settings\UserXP\Desktop\PROJECT\Flowcode_V4_Examples\Examples\Components\Zigbee\Exercise 2\Node 1.c
FCD_Zigbee0_Connect_To_Coordinator in: C:\Documents and Settings\UserXP\Desktop\PROJECT\Flowcode_V4_Examples\Examples\Components\Zigbee\Exercise 2\Node 1.c
FCD_Zigbee0_Connect_To_All in: C:\Documents and Settings\UserXP\Desktop\PROJECT\Flowcode_V4_Examples\Examples\Components\Zigbee\Exercise 2\Node 1.c
FCD_Zigbee0_Connect_To_Name in: C:\Documents and Settings\UserXP\Desktop\PROJECT\Flowcode_V4_Examples\Examples\Components\Zigbee\Exercise 2\Node 1.c
FCD_Zigbee0_Node_Configure_Sleep in: C:\Documents and Settings\UserXP\Desktop\PROJECT\Flowcode_V4_Examples\Examples\Components\Zigbee\Exercise 2\Node 1.c
FCD_Zigbee0_Node_Wake in: C:\Documents and Settings\UserXP\Desktop\PROJECT\Flowcode_V4_Examples\Examples\Components\Zigbee\Exercise 2\Node 1.c
FCD_Zigbee0_Read_AT_Response in: C:\Documents and Settings\UserXP\Desktop\PROJECT\Flowcode_V4_Examples\Examples\Components\Zigbee\Exercise 2\Node 1.c
FCD_Zigbee0_Read_Address_From_Buffer in: C:\Documents and Settings\UserXP\Desktop\PROJECT\Flowcode_V4_Examples\Examples\Components\Zigbee\Exercise 2\Node 1.c
FCD_Zigbee0_Read_Name_From_Buffer in: C:\Documents and Settings\UserXP\Desktop\PROJECT\Flowcode_V4_Examples\Examples\Components\Zigbee\Exercise 2\Node 1.c
FCD_Zigbee0_Scan_
License restricted by the following files:
Node 1.obj
Recompile the code with a less restrictive compiler license!
License exceeded by RAM: 5 bytes
License exceeded by ROM: 1423 words
You have reached the limit of the Lite License (Unregistered)
You can upgrade your license. Please visit: http://www.sourceboost.com
failure
Return code = -2
Flowcode was unable to assemble the ASM file due to the following errors:
FINISHED
Re: problem in compiling the program
Hello arush.
Could it be you still need to enter all your correct registration details?
Since size of program you are compiling would exceed the size limit of a trial version of Flowcode.
To Check if registered or not . Click 'Help', 'About Flowcode'.
If it states unregistered, then click 'Help', 'Register...'
The way I register is found here:
http://www.matrixmultimedia.com/mmforum ... 38&p=15927
Best to Run Flowcode in Administrator mode before entering keys if unregistered.
arush
Post by arush »
thanks...but i dnt no it'll work or no because i've given all possible tries...
Something else to try.
Take a look here:
http://www.matrixmultimedia.com/support ... f=22&t=557
arush
Post by arush »
hi sir,
as per you said, i have tried to look for help and hen about flowcode, then the message thats comes on the screen is as below,
Flowcode
50 User Educational Version
Registered to:Southampton Solent University
that means its registered version, so i don,why i can't able yo compile the program on pic, its giving the error.
kind regards-arush
