Dear Ben/Steve
Using the LCD board, it is always a trouble to connect the V+ to the mainboard power supply. If I am correct, the power needed of this LCD board can easily be powered by one of the ports A until E of a PIC IC on the main board EB006. If that is true, the V+ can be optionally taken from one pin of the Sub9D connector. There is a small extention necessary on the LCD board, just by extention of the connector P1 with a V+ pin. See attachments.
This introduce also a possiblity to swithc the LCD on/off by the flowcode.
Even if the power of the PIC will not be enough, this extention will be very helpfull in cases the LCD board is used in your own setup, where it is easy to connect one of the two pins left of the sub 9D connector with V+, preventing an apart power line.
Suggestion extending LCD EB005 board
- Jan Lichtenbelt
- Has thanked: 128 times
- Been thanked: 264 times
- Suggestion improvement EB005.jpg (9.53 KiB) Viewed 2799 times
- recent EB005.jpg (15.76 KiB) Viewed 2799 times
- Dan81
- Been thanked: 60 times
Re: Suggestion extending LCD EB005 board
Hello Jan
You can put a small wire between pin 6 or 7 of P2 and the +V of the two way screw terminal.
In the flowchart
output : 1 => RC7
delay : 100ms (or less)
macro component : init LCD
but during reset or programming , LCD will OFF.
I use this trick for many homemade Eblocks (joystick, RS485 DMX, I2C, ..).
Daniel
In the flowchart
output : 1 => RC7
Daniel
