Dear All:
Could you be so kindly to explain me how to change the Serial output, flowcode macro RS232 normally has a true output, but I have a LCD color Display, it works using an inverted output
RS232 from T to N
Re: RS232 from T to N
How about using an inverting buffer chip or a diode to flip the logic?
Other then this you will have to use the bit banged mode and manually edit the C code to produce an inverted output signal.
Seems strange though most UART based devices will work with RS232 signal lines being logic high and the start bits being logic low.
