I am wondering what enhancements come with the professional version of Flowcode4.
I am finding it to be a challenge to to floating point trig. How do you display a floating point (fractional) result on a LCD.
Thanks.
Enhancements of Flowcode4 Pro
Re: Enhancements of Flowcode4 Pro
To display a floating point number on the LCD you have to convert the float variable into a string. There is a function to do this available from the string manipulation icon. The Flowcode marketting datasheet details all of the key features between the different license variations.
- DavidA
- Has thanked: 58 times
- Been thanked: 258 times
The marketing data sheet is located here :
http://www.matrixmultimedia.com/datashe ... C-60-4.pdf
the details you want are on page 8.
billduck
- Has thanked: 23 times
- Been thanked: 16 times
Where is the "string manipulation icon?". I am using the student version, and I only see string, when a variable is declared.
Thanks.
Thanks.
The string manuipulation icon is directly below the calculation icon in the command toolbox.
Sean
- Has thanked: 6 times
- Been thanked: 44 times
The V4 AVR floating-point article (Articles section of the forum) shows how the standard library sprintf function can be used in a Flowcode C block to convert numbers to strings - using a variety of formats - before printing to an LCD.
