"avrdude.exe has stopped working"
billduck
Has thanked: 23 times
Been thanked: 16 times
Post by billduck »
I get the above message when trying to communicate with a laptop (Vista Home,64 bit) via USB to an AT90USB162 from Bipom. The parameters of: AVRDUDE %a %t "%D\%f.hex" "%f.hex" %cfg %c0 %c1 %c2 %c3 Does anyone have any suggestions?
I note there are a few posts concerning this.
billduck
Re: "avrdude.exe has stopped working"
Post by billduck »
I note the post <http://www.matrixmultimedia.com/mmforum ... UDE#p19537>
Should I be using the AVRISP mkII? I am not at this time.
I tried the work around detailed in the above post, going from the computer USB to the Bipom board USB, without success.
Thanks. Bill S
I think you may need to be using FLIP / BatchISP from Atmel to program this device via a bootloader.
BiPOM may have some information about this. I will contact them and post it here.
billduck
Post by billduck »
The solution, from Bipom, is to use the AVRISP Mk2. Thanks
