An interesting new function in Flowcode v4 is C Code Customization.
With v3, it was possible to customize but you were obliged to modify a file in a sub directory of ..\Flowcode\.. and when you went off with your laptop, the modified file stayed at home (or at the office) in your desktop computer.
Now you only need to (remember to) take your Flowchart.
Now I frequently use this new function.
RS232 is a little bit old , but there is always a system which uses it and of course needs PARITY !
The only thing to do is to put an RS232 component, click "Custom Code" then "Import" and select the right file ( Parity_Even.fcc or Parity_Odd.fcc ).
I've made several tests (Software and UART1, I don't get Pic with UART2) it seems to be OK.
Daniel
PS : see also 3C : RS232 Parity (2)
3C : RS232 Parity (1)
- Dan81
- Been thanked: 60 times
- Parity_Even.fcc
- customized component macro file
- (22.37 KiB) Downloaded 669 times
- Receive_Even.fcf
- for example
- (32.6 KiB) Downloaded 714 times
- Send_Even.fcf
- for example
- (29.04 KiB) Downloaded 691 times
Re: 3C : RS232 Parity (1)
Dan81,
I am not a C programmer and i do not understand the code of components, so how to change that is even more a mistery to me.
After i import your 232 component, what do i have to do to send/receive in odd or even parity?
I have looked at your sample files but at the extende properties of the RS232 component 8 bit is checked, is this correct or should it be 9 bit?
Thanks for your reply
Better safe then sorry
- Dan81
When "even.fcc" (or "odd.fcc") is imported, the only thing you have to do is to select the baud rate.
Don't touch anything else. (9th bit is declared in the *.fcc).
Parity can't be changed "on the fly" ( I don't think it is useful).
Then you've just got to use "SendRS232Char" ("ReceiveRS232Char") as you do without parity.
Daniel
Daniel
hello dan
i've tried your even and odd files importing them in the component, but i get errors when i start compiling.
I'm using flowcode v5 and a PIC 18F26k22.
do you think it can be related to any of those ?
many thanks for your help
seb
seb
Spanish_dude
- Has thanked: 63 times
- Been thanked: 102 times
