ADC 18F2580
Forum for problems or queries regarding other Flowcode Components. Eg LEDs, Switches, LCD, Gfx LCD etc
Rob
Flowcode V4 User
ADC 18F2580
Post by Rob »
Hi, I am trying to use six ADC channels on a 18F2580 however the flow code program (I have tried 3 & 4, both full versions) does not follow the seqence i.e. ADC0-4,ADC8-10 instead it goes ADC0-7 ?
I tried to edit the fcd file but it did not seem to have an effect. Any help would be most welcome :P
Thanks for your time
Rob
Re: ADC 18F2580
Hello Rob,
This updated v3 FCD file now fixes the misnumbered ADC channels.
To fix the FCD file I changed the ADCPins count from 8 to 11 and changed the ADCPins so that the unused channels are set to 0. I will fix the problem in the FCD source so the next release of Flowcode will have all the correct FCDs for these devices.
18F2580.fcd
(7.14 KiB) Downloaded 491 times
Rob
Flowcode V4 User
Re: ADC 18F2580
Post by Rob »
Benji,
The file worked on flowcode 3 and I inserted the changes into the flowcode 4 fcd and now that seems to work fine as well,
thank you for the speedy reply :P
Rob
