several problems with PIC18F25J50 the second
HjH
Been thanked: 2 times
Post by HjH »
I have a PIC18F25J50 controller.
1. I design a RS232 Programm. If I build the programm I get folowing warning.
Flowcode3.c: main()
733: FCI_CONCATENATE("Test, ",6,"",0,FCV_M_SEND,20);
^ (359) nicht erlaubte Umwandlung between pointer types (warning)
HI-TECH C PRO for the PIC18 MCU Family (Lite) V9.63PL3
This warning concatenate the variable with a wrong string
2. How I can change the C-code and build the programm without that flowcode overwrite the C-code
Can you help me.
Re: several problems with PIC18F25J50 the second
I have answered you elsewhere about having commas inside of strings.
Instead of using
"Test, "
Try instead using
"Test\, "
If this does not work then you must place "Test, " into a string variable and then call the string variable from the concatenate parameters input.
str = "Test, "
FCI_CONCATENATE(str, 6,"",0,FCV_M_SEND,20);
