C ASM PROGRAMING
ivan sandler
C ASM PROGRAMING
Post by ivan sandler »
STEVE
THANK YOU FOR ANSWERING ME BACK BELOW IS THE FLOW CODE C SOFTWARE.
NOW I DID THE PROGRAMING IN FLOWCODE 4 AND WHEN I TRIED TO COMPILE IT TO ASM OR TO HEX IT GAVE ME 2 ERRORS
AS I STATED ALREADY IT WORK PERFECTLY ON THE SIMULATOR
REGARDS
IVAN
PS: I DO NOT KNOW HOW TO ATTACHE THE FLOWCODE FILE SO IF YOU SEND ME A EMAIL ADDRESS I CAN SEND IT TO YOU
THIS IS THE MESSAGE I GOT BELOW
Launching the compiler...
C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\boostc.pic16.flowcode.exe -v -t PIC16F877A "YOU TUBE DIGITAL LOCK.c"
BoostC Optimizing C Compiler Version 6.95 (for PIC16 architecture)
http://www.sourceboost.com
Copyright(C) 2004-2009 Pavel Baranov
Copyright(C) 2004-2009 David Hobday
Single user Lite License (Unregistered) for 0 node(s)
Limitations: PIC12,PIC16 max code size:2048 words, max RAM banks:2, Non commercial use only
Starting preprocessor: C:\PROGRA~1\MATRIX~1\FLOWCO~1\BoostC\pp.exe "C:\Documents and Settings\Ivan Sandler\My Documents\YOU TUBE DIGITAL LOCK.c" -i C:\PROGRA~1\MATRIX~1\FLOWCO~1\BoostC\include -d _PIC16F877A -la -c2 -o "C:\Documents and Settings\Ivan Sandler\My Documents\YOU TUBE DIGITAL LOCK.pp" -v -d _BOOSTC -d _PIC16
C:\Documents and Settings\Ivan Sandler\My Documents\YOU TUBE DIGITAL LOCK.c(246): error: missing semicolon
C:\Documents and Settings\Ivan Sandler\My Documents\YOU TUBE DIGITAL LOCK.c(181): error: failure
failure
Return code = 1
FINISHED
//** File name: C:\Documents and Settings\Ivan Sandler\My Documents\YOU TUBE DIGITAL LOCK.c
//** Generated by: Flowcode v4.3.7.63
//** Date: Tuesday, August 31, 2010 20:03:55
//** Licence: Professional
//** Registered to: ivan sandler
//** http://www.matrixmultimedia.com
#define MX_PIC
//Defines for microcontroller
#define P16F877A
#define MX_EE
#define MX_EE_TYPE2
#define MX_EE_SIZE 256
#define MX_SPI
#define MX_SPI_C
#define MX_SPI_SDI 4
#define MX_SPI_SDO 5
#define MX_SPI_SCK 3
#define MX_UART
#define MX_UART_C
#define MX_UART_TX 6
#define MX_UART_RX 7
#define MX_I2C
#define MX_MI2C
#define MX_I2C_C
#define MX_I2C_SDA 4
#define MX_I2C_SCL 3
#define MX_PWM
#define MX_PWM_CNT 2
#define MX_PWM_TRIS1 trisc
#define MX_PWM_1 2
#define MX_PWM_TRIS2 trisc
#define MX_PWM_2 1
//Functions
#define MX_CLK_SPEED 19660800
#ifdef _BOOSTC
#include <system.h>
#endif
#ifdef HI_TECH_C
#include <pic.h>
#endif
//Configuration data
//Internal functions
#include "C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h"
//Macro function declarations
void FCM_TESTCODE();
void FCM_CORRECT_CODE();
void FCM_WRONG_CODE();
//Variable declarations
char FCV_KEYPADNUMBER;
char FCV_DIGIT1;
char FCV_DIGIT2;
char FCLV_LOOP1;
//Defines:
/**** Macro Substitutions ****
{'1','4','7','*','2','5','8','0','3','6','9','#'} = Key List (Numbers)
{1,4,7,10,2,5,8,0,3,6,9,11} = Key List (Characters)
tris` = Row Data Direction Register
port` = Row Port Register
3 = Number Of Columns
4 = Number Of Rows
trisc = Column Data Direction Register
portc = Column Port Register
1 = Column 1 mask
2 = Column 2 mask
4 = Column 3 mask
1 = Column 4 mask
1 = Row 1 mask
1 = Row 2 mask
1 = Row 3 mask
1 = Row 4 mask
//KeyPad(0): //Macro function declarations
char FCD_KeyPad0_GetKeypadNumber();
char FCD_KeyPad0_GetKeypadAscii();
//Defines:
portb = D1 Port
trisb = D1 Data Direction
portb = D2 Port
trisb = D2 Data Direction
portb = D3 Port
trisb = D3 Data Direction
portb = D4 Port
trisb = D4 Data Direction
portb = RS Port
trisb = RS Data Direction
portb = E Port
trisb = E Data Direction
0 = Data 1_Pin
1 = Data 2 Pin
2 = Data 3 Pin
3 = Data 4 Pin
4 = RS Pin
5 = Enable Pin
LCD_1114936 = Unique Component Reference Number
2 = Row Count
16 = Column Count
//component connections
#define LCD_1114936_PORT0 portb
#define LCD_1114936_TRIS0 trisb
#define LCD_1114936_PORT1 portb
#define LCD_1114936_TRIS1 trisb
#define LCD_1114936_PORT2 portb
#define LCD_1114936_TRIS2 trisb
#define LCD_1114936_PORT3 portb
#define LCD_1114936_TRIS3 trisb
#define LCD_1114936_PORT4 portb
#define LCD_1114936_TRIS4 trisb
#define LCD_1114936_PORT5 portb
#define LCD_1114936_TRIS5 trisb
#define LCD_1114936_BIT0 0
#define LCD_1114936_BIT1 1
#define LCD_1114936_BIT2 2
#define LCD_1114936_BIT3 3
#define LCD_1114936_RS 4
#define LCD_1114936_E 5
#define LCD_1114936_ROWCNT 2
#define LCD_1114936_COLCNT 16
#ifdef _BOOSTC
#define LCD_1114936_DELAY delay_10us(10)
#endif
#ifdef _C2C_
#define LCD_1114936_DELAY delay_us(100)
#endif
#ifdef HI_TECH_C
#define LCD_1114936_DELAY __delay_us(120)
#endif
#ifndef LCD_1114936_DELAY
#endif
//LCDDisplay(0): //Macro function declarations
void FCD_LCDDisplay0_RawSend(char in, char mask);
void FCD_LCDDisplay0_Start();
void FCD_LCDDisplay0_Clear();
void FCD_LCDDisplay0_PrintASCII(char Character);
void FCD_LCDDisplay0_Command(char in);
void FCD_LCDDisplay0_Cursor(char x, char y);
void FCD_LCDDisplay0_PrintNumber(short Number);
void FCD_LCDDisplay0_PrintString(char* String, char MSZ_String);
void FCD_LCDDisplay0_ScrollDisplay(char Direction, char Num_Positions);
void FCD_LCDDisplay0_ClearLine(char Line);
void FCD_LCDDisplay0_RAM_Write(char nIdx, char d0, char d1, char d2, char d3, char d4, char d5, char d6, char d7);
//KeyPad(0): //Macro implementations
//get matrices for rows and columns
#if (3 == 1)
#define KPAD_COL_MTX {1}
#define KPAD_COL_MASK (1)
#endif
#if (3 == 2)
#define KPAD_COL_MTX {1,2}
#define KPAD_COL_MASK (1|2)
#endif
#if (3 == 3)
#define KPAD_COL_MTX {1,2,4}
#define KPAD_COL_MASK (1|2|4)
#endif
#if (3 == 4)
#define KPAD_COL_MTX {1,2,4,1}
#define KPAD_COL_MASK (1|2|4|1)
#endif
#if (4 == 1)
#define KPAD_ROW_MTX {1}
#define KPAD_ROW_MASK (1)
#endif
#if (4 == 2)
#define KPAD_ROW_MTX {1,1}
#define KPAD_ROW_MASK (1|1)
#endif
#if (4 == 3)
#define KPAD_ROW_MTX {1,1,1}
#define KPAD_ROW_MASK (1|1|1)
#endif
#if (4 == 4)
#define KPAD_ROW_MTX {1,1,1,1}
#define KPAD_ROW_MASK (1|1|1|1)
#endif
#ifndef KPAD_COL_MTX
#ifdef _BOOSTC
#pragma error "Keypad error: column count is not 1-4"
#endif
#ifdef HI_TECH_C
#error Keypad error: column count is not 1-4
#endif
#endif
#ifndef KPAD_ROW_MTX
#ifdef _BOOSTC
#pragma error "Keypad error: row count is not 1-4"
#endif
#ifdef HI_TECH_C
#error Keypad error: row count is not 1-4
#endif
#endif
//store keys and pin connections into a constant array
#ifdef _BOOSTC
rom char* mtxKeysAsNumbers = {1,4,7,10,2,5,8,0,3,6,9,11};
rom char* mtxCols = KPAD_COL_MTX;
rom char* mtxRows = KPAD_ROW_MTX;
#endif
#ifdef HI_TECH_C
const char mtxKeysAsNumbers[] = {1,4,7,10,2,5,8,0,3,6,9,11};
const char mtxCols[] = KPAD_COL_MTX;
const char mtxRows[] = KPAD_ROW_MTX;
#endif
//set up i/o of port (rows = inputs, columns = outputs)
tris` = (tris` | KPAD_ROW_MASK);
trisc = (trisc & ~KPAD_COL_MASK); //BR
char iCol;
char iRow;
char c_ip;
for (iCol=0; iCol<3; iCol++)
//output the appropriate column high
portc = mtxCols[iCol];
//delay
delay_us(10);
//read the port
c_ip = port`;
//check for a hit
for (iRow=0; iRow<4; iRow++)
if ((c_ip & mtxRows[iRow]) != 0)
//found it!
goto found_key;
//if it gets here, it has not been found...
return (255);
found_key:
return (mtxKeysAsNumbers[(iCol*4) + iRow]);
#undef KPAD_COL_MTX
#undef KPAD_ROW_MTX
#undef KPAD_COL_MASK
#undef KPAD_ROW_MASK
#if (3 == 1)
#endif
#if (3 == 2)
#endif
#if (3 == 3)
#endif
#if (3 == 4)
#endif
#if (4 == 1)
#endif
#if (4 == 2)
#endif
#if (4 == 3)
#endif
#if (4 == 4)
#endif
#ifdef _BOOSTC
#endif
#ifdef HI_TECH_C
#endif
#endif
#ifdef _BOOSTC
#endif
#ifdef HI_TECH_C
#endif
#endif
#ifdef _BOOSTC
rom char* mtxKeysAsChars = {'1','4','7','*','2','5','8','0','3','6','9','#'};
#endif
#ifdef HI_TECH_C
const char mtxKeysAsChars[] = {'1','4','7','*','2','5','8','0','3','6','9','#'};
#endif
char iCol;
char iRow;
char c_ip;
//delay
delay_us(10);
//read the port
c_ip = port`;
//check for a hit
//found it!
goto found_key;
return (255);
found_key:
return (mtxKeysAsChars[(iCol*4) + iRow]);
#undef KPAD_COL_MTX
#undef KPAD_ROW_MTX
//LCDDisplay(0): //Macro implementations
unsigned char pt;
clear_bit(LCD_1114936_PORT0, LCD_1114936_BIT0);
clear_bit(LCD_1114936_PORT1, LCD_1114936_BIT1);
clear_bit(LCD_1114936_PORT2, LCD_1114936_BIT2);
clear_bit(LCD_1114936_PORT3, LCD_1114936_BIT3);
clear_bit(LCD_1114936_PORT4, LCD_1114936_RS);
clear_bit(LCD_1114936_PORT5, LCD_1114936_E);
pt = ((in >> 4) & 0x0f);
if (pt & 0x01)
set_bit(LCD_1114936_PORT0, LCD_1114936_BIT0);
if (pt & 0x02)
set_bit(LCD_1114936_PORT1, LCD_1114936_BIT1);
if (pt & 0x04)
set_bit(LCD_1114936_PORT2, LCD_1114936_BIT2);
if (pt & 0x08)
set_bit(LCD_1114936_PORT3, LCD_1114936_BIT3);
if (mask)
set_bit(LCD_1114936_PORT4, LCD_1114936_RS);
LCD_1114936_DELAY;
set_bit (LCD_1114936_PORT5, LCD_1114936_E);
LCD_1114936_DELAY;
clear_bit (LCD_1114936_PORT5, LCD_1114936_E);
pt = (in & 0x0f);
LCD_1114936_DELAY;
if (pt & 0x01)
if (pt & 0x02)
if (pt & 0x04)
if (pt & 0x08)
if (mask)
LCD_1114936_DELAY;
LCD_1114936_DELAY;
LCD_1114936_DELAY;
clear_bit(LCD_1114936_TRIS0, LCD_1114936_BIT0);
clear_bit(LCD_1114936_TRIS1, LCD_1114936_BIT1);
clear_bit(LCD_1114936_TRIS2, LCD_1114936_BIT2);
clear_bit(LCD_1114936_TRIS3, LCD_1114936_BIT3);
clear_bit(LCD_1114936_TRIS4, LCD_1114936_RS);
clear_bit(LCD_1114936_TRIS5, LCD_1114936_E);
Wdt_Delay_Ms(12);
FCD_LCDDisplay0_RawSend(0x33, 0);
Wdt_Delay_Ms(2);
Wdt_Delay_Ms(2);
FCD_LCDDisplay0_RawSend(0x32, 0);
Wdt_Delay_Ms(2);
FCD_LCDDisplay0_RawSend(0x2c, 0);
Wdt_Delay_Ms(2);
FCD_LCDDisplay0_RawSend(0x06, 0);
Wdt_Delay_Ms(2);
FCD_LCDDisplay0_RawSend(0x0c, 0);
Wdt_Delay_Ms(2);
//clear the display
FCD_LCDDisplay0_RawSend(0x01, 0);
Wdt_Delay_Ms(2);
FCD_LCDDisplay0_RawSend(0x02, 0);
Wdt_Delay_Ms(2);
Wdt_Delay_Ms(2);
Wdt_Delay_Ms(2);
FCD_LCDDisplay0_RawSend(Character, 0x10);
FCD_LCDDisplay0_RawSend(in, 0);
Wdt_Delay_Ms(2);
#if (LCD_1114936_ROWCNT == 1)
y=0x80;
#endif
#if (LCD_1114936_ROWCNT == 2)
if (y==0)
y=0x80;
else
y=0xc0;
#endif
#if (LCD_1114936_ROWCNT == 4)
if (y==0)
y=0x80;
else if (y==1)
y=0xc0;
#if (LCD_1114936_COLCNT == 16)
else if (y==2)
y=0x90;
else
y=0xd0;
#endif
#if (LCD_1114936_COLCNT == 20)
else if (y==2)
y=0x94;
else
y=0xd4;
#endif
#endif
FCD_LCDDisplay0_RawSend(y+x, 0);
Wdt_Delay_Ms(2);
short tmp_int;
char tmp_byte;
if (Number < 0)
FCD_LCDDisplay0_RawSend('-', 0x10);
Number = 0 - Number;
tmp_int = Number;
if (Number >= 10000)
tmp_byte = tmp_int / 10000;
FCD_LCDDisplay0_RawSend('0' + tmp_byte, 0x10);
while (tmp_byte > 0)
tmp_int = tmp_int - 10000;
tmp_byte--;
if (Number >= 1000)
tmp_byte = tmp_int / 1000;
tmp_int = tmp_int - 1000;
tmp_byte--;
if (Number >= 100)
tmp_byte = tmp_int / 100;
tmp_int = tmp_int - 100;
tmp_byte--;
if (Number >= 10)
tmp_byte = tmp_int / 10;
tmp_int = tmp_int - 10;
tmp_byte--;
FCD_LCDDisplay0_RawSend('0' + tmp_int, 0x10);
char idx = 0;
for (idx=0; idx<MSZ_String; idx++)
#ifdef _BOOSTC
if (String[idx] == 0)
break;
FCD_LCDDisplay0_RawSend(String[idx], 0x10);
#endif
#ifdef HI_TECH_C
if (*String == 0)
break;
FCD_LCDDisplay0_RawSend(*String, 0x10);
String++;
#endif
char cmd = 0;
char count;
//Choose the direction
switch (Direction)
case 0:
case 'l':
case 'L':
cmd = 0x18;
break;
case 1:
case 'r':
case 'R':
cmd = 0x1C;
break;
default:
break;
//If direction accepted then scroll the specified amount
if (cmd)
for (count = 0; count < Num_Positions; count++)
FCD_LCDDisplay0_Command(cmd);
char count;
char rowcount;
//Define number of columns per line
rowcount=80;
#endif
rowcount=40;
#endif
rowcount=16;
#endif
rowcount=20;
#endif
#endif
//Start at beginning of the line
FCD_LCDDisplay0_Cursor (0, Line);
//Send out spaces to clear line
for (count = 0; count < rowcount; count++)
FCD_LCDDisplay0_RawSend(' ', 0x10);
//Move back to the beginning of the line.
//set CGRAM address
FCD_LCDDisplay0_RawSend(64 + (nIdx << 3), 0);
delay_ms(2);
//write CGRAM data
FCD_LCDDisplay0_RawSend(d0, 0x10);
FCD_LCDDisplay0_RawSend(d1, 0x10);
FCD_LCDDisplay0_RawSend(d2, 0x10);
FCD_LCDDisplay0_RawSend(d3, 0x10);
FCD_LCDDisplay0_RawSend(d4, 0x10);
FCD_LCDDisplay0_RawSend(d5, 0x10);
FCD_LCDDisplay0_RawSend(d6, 0x10);
FCD_LCDDisplay0_RawSend(d7, 0x10);
//Clear the display
delay_ms(2);
delay_ms(2);
void FCM_TESTCODE()
//FIRST NUMBER
//Decision: DIGIT1=8?
if (FCV_DIGIT1==8)
//Decision
//Decision: DIGIT2=4?
if (FCV_DIGIT2==4)
//CORRECT_CODE
//Call Macro: CORRECT_CODE
FCM_CORRECT_CODE();
} else {
//Call Macro
//Call Macro: WRONG_CODE
FCM_WRONG_CODE();
} else {
//Call Macro
FCM_WRONG_CODE();
//Call Component Macro
//Call Component Macro: LCDDisplay(0)::Clear
//Call Component Macro: LCDDisplay(0)::Cursor(0, 0)
FCD_LCDDisplay0_Cursor(0, 0);
//Call Component Macro: LCDDisplay(0)::PrintASCII(" CORRECT CODE")
FCD_LCDDisplay0_PrintASCII(' ');
FCD_LCDDisplay0_PrintASCII('C');
FCD_LCDDisplay0_PrintASCII('O');
FCD_LCDDisplay0_PrintASCII('R');
FCD_LCDDisplay0_PrintASCII('E');
FCD_LCDDisplay0_PrintASCII('T');
FCD_LCDDisplay0_PrintASCII('D');
//Call Component Macro: LCDDisplay(0)::Cursor(0, 1)
FCD_LCDDisplay0_Cursor(0, 1);
//Call Component Macro: LCDDisplay(0)::PrintASCII(" PUSH THE DOOR NOW")
FCD_LCDDisplay0_PrintASCII('P');
FCD_LCDDisplay0_PrintASCII('U');
FCD_LCDDisplay0_PrintASCII('S');
FCD_LCDDisplay0_PrintASCII('H');
FCD_LCDDisplay0_PrintASCII('N');
FCD_LCDDisplay0_PrintASCII('W');
//LOCK OPEN
//Output: 1 -> A0
trisa = trisa & 0xfe;
if (1)
porta = (porta & 0xfe) | 0x01;
else
porta = porta & 0xfe;
//Delay
//Delay: 3 s
delay_s(3);
//LOCK LOCKED
//Output: 0 -> A0
if (0)
else
//Loop
//Loop: Loop 5 times
for (FCLV_LOOP1=0; FCLV_LOOP1<5; FCLV_LOOP1++)
//Call Component Macro: LCDDisplay(0)::PrintASCII(" WARNING WRONG")
FCD_LCDDisplay0_PrintASCII('A');
FCD_LCDDisplay0_PrintASCII('I');
FCD_LCDDisplay0_PrintASCII('G');
//Call Component Macro: LCDDisplay(0)::PrintASCII("CODE TRY AGAIN")
FCD_LCDDisplay0_PrintASCII('Y');
//Delay
//Delay: 500 ms
delay_ms(255);
delay_ms(245);
//Delay
//Delay: 500 ms
delay_ms(255);
delay_ms(245);
void main()
//Initialisation
adcon1 = 0x07;
//Interrupt initialisation code
option_reg = 0xC0;
//Connection Point
//Connection Point: [E]: E
FCC_Main_E:
//Call Component Macro: LCDDisplay(0)::Start
//Delay
//Delay: 250 ms
delay_ms(250);
//Call Component Macro: LCDDisplay(0)::PrintASCII(" ENTER CODE ")
//Loop
//Loop: While 1
while (1)
//Connection Point
//Connection Point: [A]: A
FCC_Main_A:
//READ THE KEYPAD NOW
//Call Component Macro: KEYPADNUMBER=KeyPad(0)::GetKeypadNumber
FCV_KEYPADNUMBER = FCD_KeyPad0_GetKeypadNumber();
//HAS THE KEYPAD BEEN PRESSED
//Decision: KEYPADNUMBER=255?
if (FCV_KEYPADNUMBER==255)
//WAITING FOR KEYPAD ENTRY
//Goto Connection Point: [A]: A
goto FCC_Main_A;
} else {
//ASSIGN KEYPAD NUMBER TO DIGIT1
//Calculation:
// DIGIT1 = KEYPADNUMBER
FCV_DIGIT1 = FCV_KEYPADNUMBER;
//Connection Point
//Connection Point: : B
FCC_Main_B:
//HAS KEYPAD BEEN RELEASED
//SET CUSOR LINE 2
//DISPLAY THE FIRST DIGIT
//Call Component Macro: LCDDisplay(0)::PrintNumber(DIGIT1)
FCD_LCDDisplay0_PrintNumber(FCV_DIGIT1);
//Connection Point
//Connection Point: [C]: C
FCC_Main_C:
//Decision
//Goto Connection Point: [C]: C
goto FCC_Main_C;
} else {
//Calculation
//Calculation:
// DIGIT2 = KEYPADNUMBER
FCV_DIGIT2 = FCV_KEYPADNUMBER;
//Connection Point
//Connection Point: [D]: D
FCC_Main_D:
//TEST CODE IF CORRECT
//Call Component Macro: LCDDisplay(0)::PrintNumber(DIGIT2)
FCD_LCDDisplay0_PrintNumber(FCV_DIGIT2);
//Call Macro
//Call Macro: TESTCODE
FCM_TESTCODE();
//Goto Connection Point: [E]: E
goto FCC_Main_E;
} else {
//Goto Connection Point: [D]: D
goto FCC_Main_D;
} else {
//Goto Connection Point: : B
goto FCC_Main_B;
mainendloop: goto mainendloop;
void MX_INTERRUPT_MACRO(void)
#define MX_PIC
#define P16F877A
#define MX_EE
#define MX_EE_TYPE2
#define MX_SPI
#define MX_SPI_C
#define MX_UART
#define MX_UART_C
#define MX_I2C
#define MX_MI2C
#define MX_I2C_C
#define MX_PWM
#define MX_PWM_1 2
#define MX_PWM_2 1
//Functions
#ifdef _BOOSTC
#include <system.h>
#endif
#ifdef HI_TECH_C
#include <pic.h>
#endif
char FCV_DIGIT1;
char FCV_DIGIT2;
char FCLV_LOOP1;
//Defines:
4 = Number Of Rows
1 = Column 1 mask
2 = Column 2 mask
4 = Column 3 mask
1 = Column 4 mask
1 = Row 1 mask
1 = Row 2 mask
1 = Row 3 mask
1 = Row 4 mask
//Defines:
portb = D1 Port
portb = D2 Port
portb = D3 Port
portb = D4 Port
portb = RS Port
portb = E Port
0 = Data 1_Pin
1 = Data 2 Pin
2 = Data 3 Pin
3 = Data 4 Pin
4 = RS Pin
5 = Enable Pin
2 = Row Count
16 = Column Count
#ifdef _BOOSTC
#endif
#ifdef _C2C_
#endif
#ifdef HI_TECH_C
#endif
#endif
#if (3 == 1)
#endif
#if (3 == 2)
#endif
#if (3 == 3)
#endif
#if (3 == 4)
#endif
#if (4 == 1)
#endif
#if (4 == 2)
#endif
#if (4 == 3)
#endif
#if (4 == 4)
#endif
#ifdef _BOOSTC
#endif
#ifdef HI_TECH_C
#endif
#endif
#ifdef _BOOSTC
#endif
#ifdef HI_TECH_C
#endif
#endif
#ifdef _BOOSTC
#endif
#ifdef HI_TECH_C
#endif
char iCol;
char iRow;
char c_ip;
//delay
delay_us(10);
//read the port
c_ip = port`;
//check for a hit
//found it!
goto found_key;
return (255);
found_key:
#undef KPAD_COL_MTX
#undef KPAD_ROW_MTX
#if (3 == 1)
#endif
#if (3 == 2)
#endif
#if (3 == 3)
#endif
#if (3 == 4)
#endif
#if (4 == 1)
#endif
#if (4 == 2)
#endif
#if (4 == 3)
#endif
#if (4 == 4)
#endif
#ifdef _BOOSTC
#endif
#ifdef HI_TECH_C
#endif
#endif
#ifdef _BOOSTC
#endif
#ifdef HI_TECH_C
#endif
#endif
#ifdef _BOOSTC
#endif
#ifdef HI_TECH_C
#endif
char iCol;
char iRow;
char c_ip;
//delay
delay_us(10);
//read the port
c_ip = port`;
//check for a hit
//found it!
goto found_key;
return (255);
found_key:
#undef KPAD_COL_MTX
#undef KPAD_ROW_MTX
unsigned char pt;
if (pt & 0x01)
if (pt & 0x02)
if (pt & 0x04)
if (pt & 0x08)
if (mask)
LCD_1114936_DELAY;
LCD_1114936_DELAY;
pt = (in & 0x0f);
LCD_1114936_DELAY;
if (pt & 0x01)
if (pt & 0x02)
if (pt & 0x04)
if (pt & 0x08)
if (mask)
LCD_1114936_DELAY;
LCD_1114936_DELAY;
LCD_1114936_DELAY;
Wdt_Delay_Ms(12);
Wdt_Delay_Ms(2);
Wdt_Delay_Ms(2);
Wdt_Delay_Ms(2);
Wdt_Delay_Ms(2);
Wdt_Delay_Ms(2);
Wdt_Delay_Ms(2);
//clear the display
Wdt_Delay_Ms(2);
Wdt_Delay_Ms(2);
Wdt_Delay_Ms(2);
Wdt_Delay_Ms(2);
Wdt_Delay_Ms(2);
y=0x80;
#endif
if (y==0)
y=0x80;
else
y=0xc0;
#endif
if (y==0)
y=0x80;
else if (y==1)
y=0xc0;
else if (y==2)
y=0x90;
else
y=0xd0;
#endif
else if (y==2)
y=0x94;
else
y=0xd4;
#endif
#endif
Wdt_Delay_Ms(2);
short tmp_int;
char tmp_byte;
if (Number < 0)
tmp_int = Number;
tmp_byte--;
if (Number >= 1000)
tmp_byte--;
if (Number >= 100)
tmp_byte--;
if (Number >= 10)
tmp_byte--;
char idx = 0;
#ifdef _BOOSTC
break;
#endif
#ifdef HI_TECH_C
if (*String == 0)
break;
String++;
#endif
char cmd = 0;
char count;
switch (Direction)
case 0:
case 'l':
case 'L':
cmd = 0x18;
break;
case 1:
case 'r':
case 'R':
cmd = 0x1C;
break;
default:
break;
if (cmd)
char count;
char rowcount;
rowcount=80;
#endif
rowcount=40;
#endif
rowcount=16;
#endif
rowcount=20;
#endif
#endif
//set CGRAM address
delay_ms(2);
//write CGRAM data
//Clear the display
delay_ms(2);
delay_ms(2);
void FCM_TESTCODE()
//FIRST NUMBER
if (FCV_DIGIT1==8)
//Decision
if (FCV_DIGIT2==4)
//CORRECT_CODE
FCM_CORRECT_CODE();
} else {
//Call Macro
FCM_WRONG_CODE();
} else {
//Call Macro
FCM_WRONG_CODE();
//LOCK OPEN
//Output: 1 -> A0
if (1)
else
//Delay
//Delay: 3 s
delay_s(3);
//LOCK LOCKED
//Output: 0 -> A0
if (0)
else
//Loop
//Delay
//Delay: 500 ms
delay_ms(255);
delay_ms(245);
//Delay
//Delay: 500 ms
delay_ms(255);
delay_ms(245);
void main()
//Initialisation
adcon1 = 0x07;
option_reg = 0xC0;
//Connection Point
FCC_Main_E:
//Delay
//Delay: 250 ms
delay_ms(250);
//Loop
//Loop: While 1
while (1)
//Connection Point
FCC_Main_A:
goto FCC_Main_A;
} else {
//Calculation:
//Connection Point
FCC_Main_B:
//SET CUSOR LINE 2
//Connection Point
FCC_Main_C:
//Decision
goto FCC_Main_C;
} else {
//Calculation
//Calculation:
//Connection Point
FCC_Main_D:
//Call Macro
FCM_TESTCODE();
goto FCC_Main_E;
} else {
goto FCC_Main_D;
} else {
goto FCC_Main_B;
Re: C ASM PROGRAMING
The problem is due to missing component connections for your keypad.
You must register on the Flowcode V4 forum to continue to receive support from us. Please follow the instructions in the link I sent you earlier today.
