v4 ecio40pin + flowkit
saschech@gmx.de
Has thanked: 1 time
Been thanked: 26 times
Post by saschech@gmx.de »
I mark icd mode in the view project options
flowkit switch is in the right pos. programming
compile to chip ok >> return= 0
flowkit switch in the left pos icd
if i click run or steep into no work
(the ecio40pin have no 5V)???????????????????????????????
I think i have do all correct after read HP299-30-1.pdf
wolfgang
Re: v4 ecio40pin + flowkit
Hello Wolfgang,
When using FlowKit, the ECIO module needs to be powered externally (i.e. not via the USB port). This is because the "ICD" setting of FlowKit does not provide power via the USB connection to the ECIO.
Unfortunately, this information is not stated in either the ECIO or the FlowKit datasheet. I will ask the relevant people to update the documentation.
