Works flowkit with int.together?
On my real hardware with a 18F6722 normal it work ok with a int,
with flowkit in run-mode there is no int?
Regrads Wolfgang
int. + flowkit
saschech@gmx.de
- Has thanked: 1 time
- Been thanked: 26 times
Re: int. + flowkit
Hello Wolfgang,
The FlowKit software disables interrupts while inside a breakpoint and then should reactivate them again once the breakpoint has been processed. Therefore interrupts should be working. What if you set a breakpoint in Flowcode inside one of your interrupt routines. Does the breakpoint ever get reached?
