How to Skip at a set number of button pushes
trisb
Flowcode V4 User
Has thanked: 6 times
Post by trisb »
Hi Guys.
I have a Simply PWM signal that goes up and down in 10% steps at the press of a button.
How ever if the Up power button is pressed 10 times and the PWM is up to 100% it will revert back to 0%.
What do i need to do to get it to skip this part of my code if the button has been pushed 10 times...
I have tried many ways but have not been able to work it out.
Could some one help my out. copy of program attached.
Thanks Tristan.
PWM test 1.fcf
(10.5 KiB) Downloaded 313 times
Re: How to Skip at a set number of button pushes
Hello Tristan,
I have added decisions into your macro to detect if the PWM is already at one or the other extreme. If the extreme is detected then the PWM signal will not be allowed to go beyond this.
PWM test 1.fcf
(11 KiB) Downloaded 323 times
trisb
Flowcode V4 User
Post by trisb »
Thanks Ben,,
That just what i was looking for.
Have a good weekend.
Tristan
Dan81
Been thanked: 60 times
Post by Dan81 »
Hello Tristan
If you want to have 10% steps (exactly) , you must change the period register to 249.
Or you will not be able to get 100% (but only 98% as you can see in the simulation)
Daniel
PWM test 2.fcf
(8.5 KiB) Downloaded 321 times
trisb
Flowcode V4 User
Post by trisb »
Thanks Daniel.
