Use interupt on whole port on rising edge
MJU
Has thanked: 121 times
Been thanked: 108 times
Post by MJU »
Is it possible to use the whole B-port as an interrupt detection, and what more, only on the rising edge?
I see the option interrupt on INT (that means the whole B-port?), but sadly I can't find a way to only make it work on the rising edge.
I use the 16F877A and want to make pushbuttons on the B port like a flip flip.
This should only work on the rising edge, when a button is pushed (no matter how long), the output is set to 1.
If the button was released and again the button was pressed, the output becomes 0.
In my opinion it's best to use interrupts on rising edge to make this work, otherwise I have to make, for every switch, a software flip flop.
Can this be done with the custom code in the interrupt settings?
Dan81
Been thanked: 60 times
Re: Use interupt on whole port on rising edge
Post by Dan81 »
Hello MJU
Try this file.
It is for a 16F887 (better and cheaper than 16F877).
For the 16F887 the 8 bits of the port B can have interrupt.
Daniel
rising_edge.fcf
not hard tested (only with Proteus)
(14 KiB) Downloaded 417 times
MJU
Post by MJU »
Thank you Dan81,
But I'm going to use the 16F877A, the 16F877 is an older version and the whole project is built around this PIC.
I thought that it would be possible with the custom code in the interupt options.
Maybe it's better to make a polling macro where I program the flip flops..
Thanks again
Hello MJU
You can use the port B interrupt, which will fire on rising and falling edge. You can then use a piece of code within the interrupt so set a flag only if port is high.
Take a look here:
http://www.matrixmultimedia.com/mmforum ... 75&p=19764
If you are struggling then post your Flowcode and I can implement it for you.
MJU
Post by MJU »
Thank you Medelec35...
But my problem is that the PIC doesn't react to the change on any of the pins on port-B.
I would think that in the interrupt settings, the setting "interrupt on: PORT" would make the PIC look for any change on port B, or am I wrong?
The INT pin on the 16F877A is B0, but isn't there a way to expand this interrupt to the whole portB?
There are custom settings that can be applied, is there a way to make the PIC react on any change on PortB?
I preffer an interrupt on a rising edge of any pin on portB.
If this is not possible I must use polling to find the change, but I would be faster to have an interrupt.
Anyway, thanks for your help!
MJU wrote:But my problem is that the PIC doesn't react to the change on any of the pins on port-B.
Your pic should react to port B interrupt on change. You are correct! If there is a change in the port b i/p's then the interrupt will be fired. All you need a a routine which ignores high to low changes.
Dan81
Post by Dan81 »
Hello MJU
Sorry I didn't see "If the button was released and again the button was pressed, the output becomes 0."
Now the filemust do what you hope.
In my previous reply I wrote : 16F887 and not 16F877, all your code must work on the 887
With 877 you have the interrup on RB4/5/6/7only but the whole port with the 887
Good luck
Daniel
flip_flop_877.fcf
(9.5 KiB) Downloaded 395 times
saschech@gmx.de
Has thanked: 1 time
Been thanked: 26 times
Post by saschech@gmx.de »
hello
If i read the datasheet,i think , there is only port b0 use for int.
(83.59 KiB) Downloaded 3009 times
Hello saschech@gmx.de.
Unfortunately some data sheets are not laid out that well. 16F877 and 16F877A with regards to interrupts look like they fall into that category.
If you look at the index regarding portb you should see the following:
portb ioc.jpg (86.26 KiB) Viewed 11848 times
As far as I am aware most microcontrollers have either portB ioc of in some smaller devices porta IOC when portb is not available.
@ Dan81
That is a really good use of ioc on rising pulse only for RB4:RB7. Since I also misread post like you did, I removed my Flowchart as yours worked with RB4:RB7, and I only included RB7
Dan81
Post by Dan81 »
About interrupt on portB : There are 2 kinds of interrupt.
- RB0/INT : where you can choose the edge rising or falling (but not both).
- RB Int on change : where an interrupt is lauched as soon as a change occurs on RB4..RB7 (and RB0..RB7 for"new" pic as 16F887).
But you have to make some jobs (reading inputs and some logical calculations) to find which RB has changed.
This interrupt is useful when you use keyboard (that's why RB port has got optional internal pull up).
If that can help
Daniel
MJU
Post by MJU »
Thanks all of you!
I appreciate all of your input.
But I have decided to step back from the interrupt idea for the switches, and use polling of the switches.
I know this is different from my first post, but my only goal was to seek for an option to make the whole port an interrupt.
Attached the way I will use the switches in my project.
If B0 is pressed, a variable is raised with 15 (and shown on the display).
No mather how long B0 is pressed, the button must first be released before another increment of the variable is allowed.
By pressing B1, the variable is set back to 0.
Maybe this way of making sure the variable isn't raised the whole time the button is pushed is too complicated, but I didn't see another way of making this work on all buttons.
If anyone has a better idea of how I can implement this (in a way it can be used with all switches), they are still welcome!
FlipFlopPoll.fcf
(11.5 KiB) Downloaded 346 times
saschech@gmx.de
Has thanked: 1 time
Hello MJU
I think it works with int on b0 ok
Regards Wolfgang
FlipFlopPoll with int.fcf
(10.5 KiB) Downloaded 292 times
MJU
Post by MJU »
Thank you Wolfgang,
But I'm leaving the interrupt option.
If the interrupt works on the whole port or I can't use it for my purpose.
I've posted my flow because it could bring other people to ideas if the ever need such a thing.
Dan81
Post by Dan81 »
Hello Marcel
My file (without interrupt ) with count up or down.
Daniel
PS : in your file LCD is connected on port A, A3 is not a general I/O , it needs pull up.
Daniel
flip_flop_877-v2.fcf
without interrupt
(11.5 KiB) Downloaded 295 times
MJU
Post by MJU »
Hey Dan81, this is a great way of flip-flop the switches, but what if by accident multiple buttons are pressed?
In that case not a single one will be counted.
I'm going to examine your solution.
Thanks!
Dan81
Post by Dan81 »
Hello Marcel
You can replace the "Switch" icon by 8 conditions.
Daniel
flip_flop_877-v3.fcf
(12.5 KiB) Downloaded 341 times
MJU
Post by MJU »
Thank you Dan81!
Strange question maybe, but why do you use a connection point (from A to A)?
Why no loop?
I'm going to use some things from this Flow!
Dan81
Post by Dan81 »
Hello Marcel
It's the same think but I prefer the "goto".
And it is the only moment when I use this icon
Daniel
