GLCD BMP ARRYAY? / SHOW IMAGES
JMANN
Post by JMANN »
I have been using the EB043 glcd, with no problems.
but now I wish to dispay an image on the LCD. what would be the process for this ?(132x132)
Im using an 18f4550(mchpusb) but I figure the size of the array would be to large so I think I would have to use an MMC/sd card for the DATA.
I thought I could plot each pixel, but how to get the colour right has me stuffed. The programs on the net I found to convert pictures seam to have 1 number (ie 0x00) per pixel. ?
here is an example of a 16x16 pixel bitmap?
#define image_width (16)
#define image_height (16)
unsigned char bitmap[]=
0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0,
0x6D, 0x6D, 0x6D, 0x6D, 0x6D, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0x6D, 0x6D, 0x6D, 0x6D, 0x6D, 0x6D,
0xFC, 0xFC, 0xFC, 0xFC, 0xFC, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xFC, 0xFC, 0xFC, 0xFC, 0xFC, 0xFC,
0x00, 0x00, 0x00, 0x00, 0x00, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0xE0, 0x00, 0x00, 0x00, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0xE0, 0xFC, 0xFC, 0xFC, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0xE0, 0x6D, 0x6D, 0x6D, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
here is one from a different program
// Image format {Width, Height, Bit Depth, Byte Count , Max Frame, ...
// Bit Depth:
//          8   bit: 0x02
//               RRRGGGBB
const unsigned char bmp[] = {
0xF, 0xF, 0x02, 0x01, 0x00,
0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4,
0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4,
0xC4, 0x6D, 0x6D, 0x6D, 0x6D, 0x6D, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0x6D, 0x6D, 0x6D, 0x6D, 0x6D, 0x6D, 0xFC, 0xFC, 0xFC,
0xFC, 0xFC, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0xFC, 0xFC, 0xFC, 0xFC, 0xFC, 0xFC, 0x0, 0x0, 0x0, 0x0, 0x0, 0xC4, 0xC4,
0xC4, 0xC4, 0xC4, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0xC4, 0x0, 0x0, 0x0, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0xC4, 0x0,
0x0, 0x0, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0x0, 0x24, 0x0, 0x0, 0x0, 0x0, 0x0, 0xC4, 0x0, 0x0, 0x0, 0xC4, 0xC4,
0xC4, 0xC4, 0xC4, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0xC4, 0xFC, 0xFC, 0xFC, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0x0,
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0xC4, 0x6D, 0x6D, 0x6D, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0x0, 0x0, 0x0, 0x0, 0x0,
0x0, 0x0, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0xC4, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0};
Is something like this possible, or am I look at this the wrong way
Anyone managed to display a picture on a glcd using flowcode?. If you have any ideas or input PLEASE POST.
Mark.
JMANN
Re: GLCD BMP ARRYAY? / SHOW IMAGES
Post by JMANN »
OK OK
So I found the C code examples. and have been playing around with Lcd_Drawimage. I changed it to make 2 different coloured lines on the lcd.
void Lcd_drawimage (char X1, char Y1)
	char i;
	Lcd_window(X1,Y1,X1+129,Y1+129);
	for (i=0;i<130;i++)			//1
		Lcd_sendbyte(PARAM, 0xFF);//white
	for (i=0;i<130;i++)
		Lcd_sendbyte(PARAM, 0X00);//black
	for (i=0;i<130;i++)
	for (i=0;i<130;i++)
All I have to do now is replace the colour with the image info. How do I do this, some kind of array?
Like the charaters?
Mark
EDIT
Alright I got the picture sorted
here is a simple Picture (Actualy from a descktop Icon).
The convertor said it was 16x16 but I could only get it to look right on 15x15.
the picture data is char bmp []
Snipet from GFX_LCD_functions.c
//Icon pic
0x0, 0x0, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0x0, 0x0, 0x0, 0xD1, 0xD1,
0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0x0, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1,
0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xCD, 0xCD, 0xCD, 0xCD, 0xCD, 0xCD, 0xCD, 0xCD,
0xCD, 0xCD, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0x6D, 0x6D, 0x6D, 0x6D, 0x6D, 0x6D, 0x6D, 0x6D, 0x6D, 0x6D, 0x6D, 0x6D, 0xCD,
0xD1, 0xD1, 0xCD, 0x24, 0xDB, 0xDB, 0xDB, 0xDB, 0xDB, 0xDB, 0xDB, 0xDB, 0xDB, 0xDB, 0x6D, 0xCD, 0xD1, 0xD1, 0xCD, 0x24,
0xDB, 0xDB, 0xDB, 0x24, 0x24, 0x24, 0x24, 0x49, 0xDB, 0xDB, 0x6D, 0xCD, 0xD1, 0xD1, 0xCD, 0x24, 0xDB, 0xDB, 0xDB, 0x24,
0xD1, 0xD1, 0x24, 0x49, 0xDB, 0xDB, 0x6D, 0xCD, 0xD1, 0xD1, 0xCD, 0x24, 0xDB, 0xDB, 0xDB, 0x24, 0xD1, 0xD1, 0x24, 0x49,
0xDB, 0xDB, 0x6D, 0xCD, 0xD1, 0xD1, 0xCD, 0x24, 0xDB, 0xDB, 0xDB, 0x24, 0xD1, 0xD1, 0x24, 0x49, 0xDB, 0xDB, 0x6D, 0xCD,
0xD1, 0xD1, 0xCD, 0x24, 0x24, 0x24, 0x24, 0xD1, 0xD1, 0xD1, 0x24, 0x24, 0xDB, 0xDB, 0x6D, 0xCD, 0xD1, 0xD1, 0xD1, 0xD1,
0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0x24, 0x24, 0x24, 0x24, 0x24, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1,
0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1,
0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0x0, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1,
0x0, 0x0, 0x0, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0xD1, 0x0, 0x0};
	char i;
	char j=0;
	Lcd_window(X1,Y1,X1+15,Y1+15);
	for (i=0;i<255;i++)
		Lcd_sendbyte(PARAM, bmp[j++]);       // send data / increment bmp
	for (i=0;i<4;i++)                                                // was missing a few pixels had to add this
		Lcd_sendbyte(PARAM, bmp[j++]); .
So because 16x16 is about the limit of the micro, how do I stream the info from say a MMC Card. I have a MMC card reader I Made and it works perfectly.
here is my demo code in full.
GLCD DEMO.rar
18F4550 MCHPUSB
(124.82 KiB) Downloaded 254 times
