Falling edge
foppa
Has thanked: 3 times
Falling edge
Post by foppa »
How do you do to get flowcode read falling edge on button release .
Would only have a signal / pulse when I release the button
Foppa :shock:
Re: Falling edge
As a suggestion:
You could use select interrupt from Int using an interrupt component macro. Then select interrupt from falling edge form the component properties.
But you must have the button connected to +ve and the int pin, with a pull down resistor. At least I believe that will work?
foppa
Re: Falling edge
Post by foppa »
Can you make an example of that.
A small program that shows the solution
8)
Re: Falling edge
Try This. I have not tested, so can't confirm will work.
Switch and resistor is connected to B0. This is common with quiet a few target devices.
INT B0 Example.fcf
(4.5 KiB) Downloaded 294 times
