gLCD EB-058
Forum for problems or queries regarding other Flowcode Components. Eg LEDs, Switches, LCD, Gfx LCD etc
Spanish_dude
Has thanked: 63 times
Been thanked: 102 times
gLCD EB-058
Post by Spanish_dude »
I'm having trouble with the gLCD.
I think my (gLCD) component connections aren't right so I'll just attach the flowcode file and log file.
I'm just trying to write some text on the gLCD...
Btw, does the backlight light up when you connect the 12V to the VPWR or do you first need to init the gLCD ?
My power supply is 12V5 approx. and the jumper of the EB-58 is set to B.
I'm using a 16F877A with a 4MHz osc.
Thanks for helping me ;)
Rgds,
Nicolas Lopez F.
Flowcode1.msg.txt
log file
(3.04 KiB) Downloaded 445 times
Flowcode1.fcf
flowcode file
(6.5 KiB) Downloaded 447 times
Re: gLCD EB-058
Hello Nicolas.
First of all you may need to update the component C code file for the new gLCD. To do this save the following file into your Flowcode v4\Components directory and overwrite the existing file when prompted.
PIC_gLCD.c
(32.57 KiB) Downloaded 480 times
Once you have done this you will need to plug the E-block into PortC for a 16F877A.
The attached program should then work correctly.
gLCD.fcf
(7 KiB) Downloaded 504 times
Spanish_dude
Re: gLCD EB-058
Hi Ben,
I forgot to mention that I'm using flowcode v3 :roll: .
