I2C software speed
Mathy
Has thanked: 30 times
Been thanked: 33 times
I2C software speed
Post by Mathy »
Hi !
I use the I2C master component in software mode.
How much is the speed in the software mode and how to increase this speed ?
Thank you for your help,
Mathy
Dan81
Been thanked: 60 times
Re: I2C software speed
Post by Dan81 »
Hello Mathy
In software , the frequency is 50kHz
If you want to modify this frequency :
- click the I2C component
- click on "Custom Code"
- select [Defines]
- click on "Edit Code"
then modify the value of the delay the line :
#define %i_MX_I2C_DELAY delay_us(10);
If you want to increase the frequency , R pull up must be decreased.
Daniel
