Flowcode 4 / Miac compile error
D.Bouchier
Has thanked: 5 times
Post by D.Bouchier »
Hello support team,
I was doing some coding in Flowcode for the MIAC and got the error message(also included as attachment):
Flowcode was unable to compile the flowchart's C code due to the following errors
There is no C-code in my flowchart so I hereby try to contact Technical Support, after I reviewed the specified line numbers in the C-code compiled from my flowchart, I could not find anything.
Attached all needed files.
Requesting support, my gratitude in advance.
Greetings
Edit: after some code tweaking it seems to be the strings that are causing the problem, but I can't seem to be able to code it differently, how do I write these strings correctly?
Even though I now use floats instead of the strings, I'm still curious how to write strings correctly
Flowcode1.c
(18.82 KiB) Downloaded 566 times
Flowcode1.msg.txt
(1.76 KiB) Downloaded 570 times
Flowcode1.fcf
(12.65 KiB) Downloaded 575 times
Re: Flowcode 4 / Miac compile error
Hiya D.Bouchier
Take the first calculation box as an example.
Could It be you are assigning a string in a calculation box with an integer?
E.g. K_Pompperiodes[] = 14580000
K_Pompperiodes is a string not a byte or an interger.
So you should drag a String manipulation box (not a calulation box). Within that String manipulation box assign all your strings
e.g. K_Pompperiodes = "14580000"
K_Koffiecansiter = "23670000"
etc.
If you see a variable with[] then its in the wrong box.
Hope his helps.
D.Bouchier
Hi Medelec,
thank you very much, this explains all my misunderstanding with strings. I have programmed in C before with strings, that's why i found it odd i could not assign them like that, but i see you can, i just need a different flowchart icon.
thanks alot!
Your welcome. Glad your sorted. At least I know who to ask when I get stuck with C :P
Thanks for letting us know.
D.Bouchier
Sure you can ask me and I will do my best to anwer :)
