On one of the sensor boards you will have to move the jumper to the patch position and then wire a link from the Microcontroller pin you wish to use to the ANASEN pin of the patch system. This should allow two analogue sensors to work together.
How to use 2 sensors??
Re: How to use 2 sensors??
Hm thats strange pin 5 (RA5) should be ok for the second analogue channel with the original analogue channel on pin 3 (RA3).
Which chip are you using and are you wiring a connections from the +V terminal of the multiprogrammer to both of the sensors boards?
Are either of the boards working correctly at the moment?
I maybe telling you something you already know, but just encase...
Random numbers are produced because pin on the microcontroller the flowchart is reading from is floating, as though nothing is connected to it.
So either wrong ADC channel is selected in flowchart for the pin to be measured, or there is an open circuit from the device plugged into the Sensor or from pin3 of P1 to pin 5 of P2 or from pin 5 of P2 to pin 8 of PIC16f877A
If you have a multimeter, with power unplugged to programmer board check there is about 220R from pins 5&6 of J6 and pin 8 of 16F877a.
If there is then best to re-check flowchart.
If not, it should be straight forward to fine out where open circuit is.
Hope this does help, and I have got it right of course.
Edit: Just a thought.
If you disconnect wire from pin 5 of P2, then connect the wire to +5V or ground, then if display shows 255 or 0, then you can tell if it's OK (software and hardware) Don't short analogue device o/p, as I would not know if it would get damaged or not.
