FLOWKIT DEBUGGER IS NOT WORKING
keshav@solus.in
Post by keshav@solus.in »
HELLO
I am using pic 18f8722 micro controller development board using pickkit3 downloaded code into my development board,
using flowkit debugger to debugg the code from development board,
I am following procedure to download the code into development board:
1)In flowcode program TICKED ICD mode after compiled and downloaded into microcontroller using MPLABIDE pickkit3 TOOL ,
2)After downloading code into board disconnected pickkit3 then connected flowkit debugger into my development board ,
3)In flowkit debugger switch is in ICD mode,
4)i am getting following error please refer http://www.matrixmultimedia.com/mmforum ... =26&t=7138
regarding this issue i posted in your forum no one be give correct solution for this issue.
Re: FLOWKIT DEBUGGER IS NOT WORKING
Have you tried a simple 1 second flasher program with the ICD disabled to ensure you have all the config settings correct. If the delays on the hardware are 1 second then you know you have everything setup correctly.
Next have you got the connections correct for the ICD in the project options and are you using the ICD pins anywhere in your program? If you are writing to the ICD port at any point then are you masking off the ICD pins?
