i2c Master
saschech@gmx.de
Has thanked: 1 time
Been thanked: 26 times
i2c Master
Post by saschech@gmx.de »
Why i can not connect to port f?
I use a 18F6722
Regards Wolfgang
(62.08 KiB) Downloaded 575 times
saschech@gmx.de
Has thanked: 1 time
Re: i2c Master
Nobody have a answer for these?
Regards Wolfgang
Re: i2c Master
Hello Wolfgang,
I think this is currently a limitation of the component properties which does not take into account larger chips with that many ports.
You can assign port F by using the custom code feature.
Edit the Defines function and look for the following lines.
#define %i_MX_PORT		  	%e
#define %i_MX_TRIS  		%f
#define %i_MX_SCL  			%g
#define %i_MX_SDA  			%h
Change to suit your connections.
eg
#define %i_MX_PORT		  	portf
#define %i_MX_TRIS  		trisf
#define %i_MX_SCL  			0
#define %i_MX_SDA  			1
