CAN2 component in flowcode V4
Nazaire VERRUE
Been thanked: 3 times
Post by Nazaire VERRUE »
I have now install Flowcode V4
CAN2 work now. The data work correct but not the identifier. The identifier
does not change. The identifier is not correct. It stay always up 688.
In attachement i have sent you the program.
What is it wrong?
Best regards
Nazaire
Oefening21a.fcf
(9 KiB) Downloaded 462 times
Sean
Has thanked: 6 times
Been thanked: 44 times
Re: CAN2 component in flowcode V4
Post by Sean »
We have been able to reproduce your results and are looking into the problem.
Sean
Post by Sean »
Here is a new version of the PIC_CAN2.c file used by Flowcode for PIC V4. The extended address commands now operate correctly with MIAC.
PIC_CAN2.c
(43.39 KiB) Downloaded 604 times
This file needs to be copied to the Components folder of the Flowcode V4 installation - overwritting the original file.
Nazaire VERRUE
Thank you Sean
The CAN2 component in flowcode V4 work now perfect.
Regard
Nazaire
