adding a programmer
siliconchip
Has thanked: 101 times
Been thanked: 25 times
adding a programmer
Post by siliconchip »
hi i am running flowcode v4 is it possible to use an easy pic 5 developement board from mikroelektronika to program my pics i was able to do this with the demo version but my hobbyist version does not work with it :cry:
Re: adding a programmer
Yes this should be possible. You will have to change the programmer settings in the Chip -> Compiler options to call the command line programming tool for your hardware. If there is no command line programmer available then you will have to take the hex file produced by Flowcode and manually load it using your programming software.
ncc1502
Has thanked: 23 times
Been thanked: 8 times
Post by ncc1502 »
I use Easypic5 from MikroElectronica
I have added at programmer location: C:\Program Files\Mikroelektronika\PICFLASH-mikroICD\PICFLASH.exe
with Parameter: -f"%f.hex"
I use the older picflash, i think it should probably work also with the newer Mikroprog suite.
Hope this helps.
Better safe then sorry
