Decimal Point in LCD
iain wilkie
Has thanked: 13 times
Been thanked: 9 times
Post by iain wilkie »
Bit stuck here ! .... I have an INT variable ... it can only be 0 to 9999, but I want to display it as 0.000 to 9.999
How do I output it to the LCD in this format ?
JohnCrow
Has thanked: 364 times
Been thanked: 716 times
Re: Decimal Point in LCD
Post by JohnCrow »
One easy way is to convert the interger to a string
Split using left$ and right $
Print string onthe LCD Int part, print a "." then print the decimal
Ive attached a very simple exmple of how to manipulate strings.
I suppose the other way would be to convert to a float and then divide by 10 or 100 ect .
But then you would still have to convert float to string to display on the lcd
Hope this helps
split string.fcf
(6.5 KiB) Downloaded 413 times
iain wilkie
That works fine for numbers like 1234 but a nuber like 55 needs to display as 0.055 ....
Iain
Dan81
Been thanked: 60 times
Post by Dan81 »
Hello Iain
In a calculation :
TH = N DIV 1000
var = N MOD 1000
HND = var DIV 100
var = var MOD 100
TEN = var DIV 10
UNT = var MOD 10
then
PRINT_NUMBER (TH)
PRINT_ASCII (',')
PRINT_NUMBER (HND)
PRINT_NUMBER (TEN)
PRINT_NUMBER (UNT)
Daniel
iain wilkie
Thanks guys ... found another solution,
The max value is 9999 so all I do is add 10000 to the value so I know it will always be 5 digits.
Then int = mid$(val,1,1)
and dec = right$(val,3)
Then just output to lcd int "." dec
Cheers
