Incorrect interrupt frequency shown in FC 4 AVR for AVR chip
nils
Post by nils »
As I was going through interrupts, I noticed that the settings for TMR0 Overflow interrupts are not showing any difference when going through prescaler values.
Is this a bug, as I remember this working correct in FC v3 for the AVR.
Kind regards,
Nils
Custom_Code.c help needed? -> http://tinyurl.com/2y2mzq
Flowchart high quality vector graphic output =>>http://tinyurl.com/6sx2sx
Sean
Has thanked: 6 times
Been thanked: 44 times
Re: Incorrect interrupt frequency shown in FC 4 AVR for AVR
Post by Sean »
The problem seems to caused by some missing information in the files that describe the target devices.
Here is a modified version of the ATmega324P file.
ATMEGA324P.fcd
(7.84 KiB) Downloaded 510 times
This file should be copied into the FCD folder of the Flowcode AVR V4 installation (with Flowcode not running).
Details:
The existing [TMR0] section of each .fcd file requires the following lines adding
MaxTimerOverflow=256
PrescaleOpt=1
Example:
[TMR0]
Name="TMR0 Overflow"
UseExplicitHandlerCode=1
FlagReg=
FlagBit=
HandlerCode="#ifndef MX_TIMER0OVF_HANDLER\n#define MX_TIMER0OVF_HANDLER\nISR(TIMER0_OVF_vect)\n{\n\tFCM_%n();\n}\n#else\n#warning The <TIMER0 OVF> interrupt has previously been enabled, so the macro <%n> may never get called.\n#endif\n"
UseExplicitEnableCode=1
EnReg=
EnBit=
EnableCode="TIMSK0 |= (1 << TOIE0);\n"
DisableCode="TIMSK0 &= ~(1 << TOIE0);\n"
OptCnt=1
TmrOpt=1
PrescaleOpt=1
Opt1="Clock Source & Prescaler Select"
Opt1Cnt=8
