In the datasheet of the DS1820 it's stated that the data of the master is send, LSB first.
Does the 1-wire component work this way? Does it always send and receives it's data LSB first?
There are macro's for the 1-wire component in Flowcode that handle the data flow to and from the DS1820, but I want to use this temperature sensor in a different way.
If I use the examples from the datasheet I get a weird response in my logic analyser.
Maybe strange, but let's say I need to send 48h and the direction is wrong, (when I use the oo_TX_byte macro), do I need to send 12h instead? 12h is 48h in the other direction.
1-Wire, LSB first
Re: 1-Wire, LSB first
The "oo_tx_byte" function always sends its data out with the least significant bit first so you do not have to do any manipulation on the data you are sending.
The 1-wire component uses delays so you may want to check that your configuration and clock speed settings are correct in Flowcode otherwise the component will not work correctly. A 1 second flasher program will confirm if you have everything set up correctly.
Also 1-wire requires an external pull up resistor to be fitted to the 1-wire signal wire. I think the value of the pull up may vary depending on the length of your bus and the number of devices connected.
MJU
- Has thanked: 121 times
- Been thanked: 108 times
Dear BenJ.
I can read the temperature when I use the DS1820 macro's.
That works fine.
I just want to read the bits of the scratchpad myself.
In the datasheet there are examples of how to address the DS1820
When I try to implement them myself with the oo_TX and the oo_RX macro's they don't work.
In the datasheet I find that first a reset, followed by a presence puls is the start.
Then a SEARCH ROM (0xF0) would return the 64bit ROM code of the DS1820.
When I issue a oo_busreset followed by a oo_ScanBus macro, I see this
Reset, presence,error,unknown,reset,presence,0XFO and then strange 24 * 8 bits.
Normally the 0XF0 should be followed by 64bits?
Strange, not what I expected.
Is there something more Matrix does in it's macro's?
The part where the line is pulled down (= ERROR) approx 620µs, followed by 620µs high (= unknown), where does this come from?
Why does the bus contain 24byte instead of 64bits?
The DS1820 family code in the ROM (10h) is nowhere to be found..
Strange :-s
That works fine.
Strange :-s
If you look at the contents of the DS1820 functions using the custom code feature then you can see that the functions are simply referencing the generic 1-wire function calls. You should be able to copy the function calls and syntax directly into Flowcode if you wish using component macros etc.
Here is the DS1820_start_conversion function as an example.
Defines such as OO_SKIPROM can be found in the defines section in the custom code window.
char in = 0;
char counter = 0;
oo_busreset();
oo_tx_byte(OO_SKIPROM); // Command all temp sensors on the bus to start a conversion
oo_tx_byte(OO_CONVERTT); // Convert temperature
while (in == 0)
in = oo_rx_byte();
delay_ms(4);
counter++;
if (counter == 0xFF) // Security: if the conversion is not completed
return 1; // after > 1 sec -> break.
return 0;Regards Ben Rowland - MatrixTSL
