I am seeking your asistance with a problem on VNET. basically i can not get the two instances to connect to the server and get an error whilst attempting RS232 simulation as per your previosly posted examples.
I go thru the sequecne of creating the node and network on flowcode V4 instance one and it responds with "you are the owner of VNET network". I am following your instructions as posted on the forum. This indicates that the server is running on the PC. I turned off the server and proved that i could not create a node.
The next step to expose the RS232 ports via the manage nodes function. this works!
I then go to instance two of flowcode 4 on the same machine and attempt to join and get the following error."join VNET request fail"
below is the debug from the flow server app. I figured out how to get it into debug mode by adding /d on the end of the command line.
[*]do you have any info on the Flowserver app? I am missing the specific help file for the flowserver application. Not sure if its a Windows 7 issue, however I cant find it on the FC4 CD either, perhaps not looking in the right place.
[*]can you tell me what the ping function does... it did not seem to do anything
configuration as followsServer: LABPC, @Address: 192.168.1.20 is running on port 4360
MSG: 4, FROM: 192.168.1.20, CURRENT: 1, TOTAL: 1, BODY: network.node1
MSG: 10, FROM: 192.168.1.20, CURRENT: 1, TOTAL: 1, BODY: network.node1,RS232(0):6,
MSG: 2, FROM: 192.168.1.20, CURRENT: 1, TOTAL: 1, BODY:
MSG: 6, FROM: 192.168.1.20, CURRENT: 1, TOTAL: 1, BODY: network.node1
2 x instance of FC4 professional
Windows 7 machine
ip addr 192.168.1.20 port 4360 on all instance including server application... server is operating on same machine
My intended purpose for VNET is a simulation of a multi node can network, however I thought i would start with sometinh simple such as your demo on RS232 - attached for your reference.
Any suggestions will be greatfully recieved
all the best
pete
