Utilising received packets
o.fithcheallaigh
Has thanked: 3 times
Post by o.fithcheallaigh »
I'm currently working on a remote control project using 877A and EB023. I've established communications using UDP across a VLAN and can print out strings sent to EB023 on the LCD.
My problem is determining the best way to use the recieved data to implement i/o changes.
I'd really appreciate any pointers or help, I'm very new to flowcode and the more detail you could give me the better. Please find my code attached.
Sean
PING__04.fcf
(25.35 KiB) Downloaded 270 times
Fuair siad bás ar son saoirse na hÉireann.
Go raibh tú leathuair ar Neamh sula mbeadh a fhios ag an diabhal go bhfuil tú marbh.
Re: Utilising received packets
I have suggested ways to do this here:
http://www.matrixmultimedia.com/mmforum ... 130#p12964
o.fithcheallaigh
I was hoping to keep it relatively simple tp start with, how would I go about moving the data received within the packet into an array
and simply compare the array with four other values. Which would determine the state of the i/o?
Sean
