Error Compiling ADC component with 16F722 - 16F727
There is an issue with Flowcode V4.3.7.63 for pic when compiling if using ADC component with 16F722 - 16F727:
File name:     D:\16f723 test.c
Generated by:  Flowcode v4.3.7.63
Date:          Friday, March 18, 2011 16:26:49
Licence:       Professional
Registered to: Martin
Launching the compiler...
C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\boostc.pic16.flowcode.exe -v -t PIC16F722 "16f723 test.c"
BoostC Optimizing C Compiler Version 6.95 (for PIC16 architecture)
http://www.sourceboost.com
Copyright(C) 2004-2009 Pavel Baranov
Copyright(C) 2004-2009 David Hobday
Licensed to FlowCode User under Single user Pro License for 1 node(s)
Limitations: PIC12,PIC16 max code size:Unlimited, max RAM banks:Unlimited
16f723 test.c
Starting preprocessor: C:\PROGRA~1\MATRIX~1\FLOWCO~2\BoostC\pp.exe "D:\16f723 test.c" -i C:\PROGRA~1\MATRIX~1\FLOWCO~2\BoostC\include -d _PIC16F722 -la -c2 -o "D:\16f723 test.pp" -v -d _BOOSTC -d _PIC16
D:\16f723 test.c(263:13): error: unknown identifier 'adresh'
D:\16f723 test.c(263:13): error: invalid operand 'adresh'
D:\16f723 test.c(263:20): error: failed to generate expression
D:\16f723 test.c(263:20): error: invalid operand '<<'
D:\16f723 test.c(263:10): error: failed to generate expression
D:\16f723 test.c(264:23): error: unknown identifier 'adresl'
D:\16f723 test.c(264:23): error: invalid operand 'adresl'
D:\16f723 test.c(264:30): error: failed to generate expression
D:\16f723 test.c(264:30): error: invalid operand '>>'
D:\16f723 test.c(264:20): error: failed to generate expression
D:\16f723 test.c(264:20): error: invalid operand '| '
D:\16f723 test.c(264:10): error: failed to generate expression
16f723 test.c success
failure
Return code = 1
FINISHED
I have traced cause of problem to PIC_ADC_18.c
Instead of:
/*Macro_SampleADC_End*/
char ReadAsByte(void)
/*Macro_ReadAsByte_Start*/
	SampleADC();
	#ifdef _BOOSTC
		#ifdef ADRES
			return ADRES;
		#else
			return ADRESH;
		#endif
	#endif
	#ifdef HI_TECH_C
		#ifdef adres
			return adres;
		#else
			return adresh;
		#endif
	#endif
/*Macro_ReadAsByte_End*/
short ReadAsInt(void)
/*Macro_ReadAsInt_Start*/
	short iRetVal;
	SampleADC();
	#ifdef adres
		iRetVal = (adres << 2);
	#else
		iRetVal = (adresh << 2);
		iRetVal = iRetVal | (adresl >> 6);
	#endif
	return (iRetVal);
/*Macro_ReadAsInt_End*/
Should be:
	SampleADC();
	#ifdef _BOOSTC
		#ifdef ADRES
			return adres;
		#else
			return adresh;
		#endif
	#endif
	#ifdef HI_TECH_C
		#ifdef adres
			return ADRES;
		#else
			return ADRESH;
		#endif
	#endif
	short iRetVal;
	SampleADC();
	#ifdef _BOOSTC
		#ifdef ADRES
		#else
		#endif
	#endif
	#ifdef HI_TECH_C
		#ifdef adres
			iRetVal = (ADRES << 2);
		#else
			iRetVal = (ADRESH << 2);
			iRetVal = iRetVal | (ADRESL >> 6);
		#endif
	#endif
	return (iRetVal);
Attached is correct version.
16f723 test.fcf
(4.5 KiB) Downloaded 508 times
PIC_ADC_18.c
(9.39 KiB) Downloaded 545 times
