I im finding it diffuclt to create a flowcode that will turn on and turn off the fan motor depending on the reading from the temperture probe.
i want the fan motor to turn on at temperture above 40⁰C and to turn off when the temperture reaches below 40⁰C.
Sorry but i have just tried to do this flowcode myself but im stuck has i am still an armature with flowcode
Any help would be appricated thank you
Fan Motor turning on/off due to reading from Temp probe.
- REMOTE_temp.fcf_avr
- (4.5 KiB) Downloaded 390 times
Re: Fan Motor turning on/off due to reading from Temp probe.
I have added a decision and a variable to allow you to set the threshold setpoint. You will need to change this from 100 to a value that represents 40 degrees with your temperature probe. Are you using the Vernier stainless steel temperature probe?
you did not attach the edited file and also i am using Wide range stainless steel temperature probe.Benj wrote:Hello,
thank you for your help
Here is the file, must have forgotten to attach it yesterday.
- (4.5 KiB) Downloaded 393 times
