e-blocks EASY CAN help
dan654321
Post by dan654321 »
hello
i have the Easy Can bundle and im stuck.
I can only send 3 buffers ,so 3 switchs N1 to 3 leds N2
How can i sent can massages from each of the 8 switchs from N1 , to 8 output leds to N2 ? .So switch 0 = led 0,switch 1 = led 1,switch 2 = led 2,switch 3 = led 3,switch 4 = led 4 ,switch 5 = led 5, switch 6 = led 6,switch 7 = led 7 .
thanks dan
Re: e-blocks EASY CAN help
You have some choices - use individual message IDs for each switch, or use 1 message ID and use the data to identify which switch has changed. It doesn't really matter, but I would vote for latter.
You can set the ID and/or data of an outgoing message within your program using an appropriate "call macro" icon for the CAN component. Similarly, you will read the CAN ID or data on the receiving node.
