Bug with V3 AVR using a subtraction calculation.
Forum for problems or queries regarding the Flowcode application and compiler usage.
I posted a Flowchart for soccermad which was created with Flowcode V3 for PIC:
http://www.matrixmultimedia.com/mmforum ... 335#p24232
It compiled for me fine with Flowcode V3 for PIC, but did not compile successfully when imported to V3 AVR
The following errors was shown within the message window:
C:\Users\SANTAN~1\DOCUME~1\FLOWCODE\REMOTE working progress_Modified2.c: In function 'FCM_Timer0_intrerput':
C:\Users\SANTAN~1\DOCUME~1\FLOWCODE\REMOTE working progress_Modified2.c:168: error: expected expression before ';' token
C:\Users\SANTAN~1\DOCUME~1\FLOWCODE\REMOTE working progress_Modified2.c:257: error: expected expression before ';' token
Return code = 1
On investigation I discovered two calculation boxes within timer interrupt was root cause :
Seconds_Timer1 = Seconds_Timer1 - 1
Seconds_Timer2 = Seconds_Timer2 - 1
These calculations had the following effect on the C file:
//Calculation
				//Calculation:
				//  Seconds_Timer1 = Seconds_Timer1 - 1
				//  0 =
				FCV_SECONDS_TIMER1 =  FCV_SECONDS_TIMER1 - 1 ;
				0 = ;
//Calculation
				//Calculation:
				//  Seconds_Timer2 = Seconds_Timer2 - 1
				//  0 =
				FCV_SECONDS_TIMER2 =  FCV_SECONDS_TIMER2 - 1 ;
				0 = ;
Solution which worked is replace Calculation boxes with a C code Boxes with
Bug was not present on Flowcode V4 AVR demo.
